E40d no forward or reverse
Old Mar 17, 2016 | 10:25 AM
  #31
Dam pile's Avatar
Dam pile
Originally Posted by Mark Kovalsky
When it didn't move did you try the 1 and 2 position? If it moved there the problem is a failed (or installed backwards) overdrive one way clutch.
Yeah I tried each gear individually super weird right could it be the reverse clutches?? I still haven't got that far lol
Old Mar 17, 2016 | 10:32 AM
  #32
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The reverse clutch won't cause a no forward. Something is broken in there. All you need to do is find it. Did you open the pump?
Old Mar 17, 2016 | 12:43 PM
  #33
Dam pile's Avatar
Dam pile
No I haven't opened up the pump yet should i? And what would I look for?
Old Mar 17, 2016 | 12:53 PM
  #34
Dam pile's Avatar
Dam pile
Could it be the pump even though it pumped it a1.5 qts in about 6secs
Old Mar 17, 2016 | 02:12 PM
  #35
Mark Kovalsky
No, it isn't the pump if it pumped. i had forgotten that.
Old Mar 17, 2016 | 05:04 PM
  #36
Dam pile's Avatar
Dam pile
This is bizarre all the clutches planetarys band bearings bushings sun gears are all in great shape idk
Old Mar 17, 2016 | 08:17 PM
  #37
Mark Kovalsky
Well if nothing is broken and everything is fine this trans will work fine. I can't inspect the parts so I can't tell you what broke, but that's the only way you can lose all gears, unless the transfer case is the problem. If it is the transfer case it won't hold in park, and you said that it does. I'm lost here, I have nothing else to add.
Old Mar 17, 2016 | 10:14 PM
  #38
wtroger's Avatar
wtroger
I had one do this. And it had a stuck pressure relief valve in the pump. No fluid pressure at the test port.
Old Mar 17, 2016 | 11:33 PM
  #39
Dam pile's Avatar
Dam pile
Ok well thank you anyways mark you have been a huge help
Old Mar 17, 2016 | 11:34 PM
  #40
Dam pile's Avatar
Dam pile
I never tested pressure I just know it pumped out a lot of fluid when I disconnected the cooler hose
Old Mar 20, 2016 | 12:57 PM
  #41
Dam pile's Avatar
Dam pile
Eureka I found it it was a stripped out torque converter it felt fine but I put my drill to it to get more torque on it and wallah it was stripped I drained fluid from converter and looked inside with flashlight and found that it was indeed stripped
Old Mar 20, 2016 | 12:59 PM
  #42
Dam pile's Avatar
Dam pile
I can't belive I tore my whole transmission apart for a bad torque converter fml live and learn I guess anyone have a step by step on how it goes back together lol
Old Apr 3, 2016 | 12:43 AM
  #43
Henry Paul Shankle's Avatar
Henry Paul Shankle
my 1992 f150 with a e40d and a 5.8 did the same thing today, left work and it shifted 1 to 2nd then nuetraled out and coasted to a stop, , holds in park so its in the trans,this thread i hope will be helpfull in diaging my problem, i am instrested to know from mark if the torque converter being stripped out, if i take it appart and find that its that, can i just change to tc and is there any way to check that b4 i take it appart
Old Apr 3, 2016 | 12:59 AM
  #44
Henry Paul Shankle
dam pile can you post a picture of ur stripped out torque converter
if u can get the camera to focus in the hole
Old Apr 3, 2016 | 07:27 AM
  #45
Mark Kovalsky
As long as nothing else is damaged you can.
No.
