What would cause shift stacking
Old Mar 14, 2016 | 11:49 AM
Benningtonr's Avatar
Benningtonr
Shift stacking when it goes 1-2-3 right after each other and your in 3rd at 20m/h (for example) and the thing is gutless.
What causes this?
Old Mar 14, 2016 | 12:20 PM
Lead Head's Avatar
Lead Head
Bad throttle position sensor, bad VSS. Start by checking for codes.
Old Mar 14, 2016 | 12:23 PM
Benningtonr
previous owner removed CEL bulb. i need to buy a test light.
Old Mar 14, 2016 | 12:26 PM
Lead Head's Avatar
Lead Head
Why not just buy a replacement check engine light bulb?
Old Mar 14, 2016 | 12:32 PM
Benningtonr
i have had the cluster out once, it was a pain. I have another cluster with a tach to put in, just haven't wanted to deal with the pain of pulling it again. Bought the tach cluster 3-4 months ago, just haven't gotten up the gumption to take the dash apart.
Old Mar 14, 2016 | 12:33 PM
Benningtonr
where is the vss located?
Old Mar 14, 2016 | 12:47 PM
Benningtonr
i have looked through alldata, and still have not come across a diagram that shows me the location.
Old Mar 14, 2016 | 01:04 PM
Freightrain's Avatar
Freightrain
On top of the rear axle.
Old Mar 14, 2016 | 01:05 PM
Benningtonr
thank you.
Old Mar 14, 2016 | 01:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What causes this?
A frequent cause of this is the PCM thinking the transfer case is in 4x4 low. There is a pin on the PCM that detects this. I forget (it's been many years) whether it looks for a ground or +12v in this circuit to indicate that it is in 4x4L.
Old Mar 16, 2016 | 11:58 AM
Benningtonr
after driving it yesterday, it is not shifting as fast as I thought, but the issue is with it being gutless in O/D. I am guessing 31 in tires and 3.31 gears are causing this.
Old Mar 16, 2016 | 12:48 PM
rla2005's Avatar
rla2005
Correction: 302 engine, 31 inch tires and 3.31 gears are causing the gutless operation in O/D.
Old Mar 16, 2016 | 01:13 PM
Benningtonr
unfortunate but true
Old Mar 16, 2016 | 01:22 PM
rla2005's Avatar
rla2005
Did you recalibrate the PSOM for the taller tires?
Old Mar 16, 2016 | 01:27 PM
Benningtonr
i do not know, but i doubt it. Truck came with the taller tires. that would have to be done by the dealer?
