Sponsored by: Real Truck
Trailer Light Issue
Old Mar 15, 2016 | 01:57 PM
ligito's Avatar
ligito
Looks like the set screw is not set on the flexible loom.
It may have loosened the screws in the connector.
Check the screws on the connector, insert the loom back in the connector, then tighten the set screw, if everything works.
Old Mar 21, 2016 | 08:03 PM
F350Man79's Avatar
F350Man79
Trailering
I switched the 2 relays with each other and the left side started working. I guess there was some corrosion or something along those lines. Thanks for all the responses!
magnoliarunner
Jan 17, 2018 11:16 AM
kylant
Nov 21, 2017 04:45 PM
gmhill33
Aug 6, 2015 09:00 PM
TWDITMORE
1997 - 2003 F150
Mar 12, 2012 09:15 PM
Thompy
1983 - 2012 Ranger & B-Series
May 2, 2007 08:52 PM
