Sponsored by: Real Truck
Procomp 22210 ... shocks?
Old Mar 13, 2016 | 07:31 PM
FordKld's Avatar
FordKld
Added some PC 22210 to the front of one of my F250's, and 2" taller blocks at the rear to level.
I know it wont ride fantastic by any means, but I think my shocks are topping out/wore out from time + the amount of lift I have now.
What are some good yet reasonably priced shocks people use? I know I will probably need longer ones so part#'s for the correct length would be helpful. I ended up with about 2.5-3" over stock both front & rear and it sits level.
Old Mar 13, 2016 | 07:43 PM
dscabra's Avatar
dscabra
I've had good experiences with Bilstein 5100's and my current ProComp MX6's. The worst "name-brand" shock I've ever used was Rough Country 2.2's.
Old Aug 16, 2016 | 03:17 PM
87beater's Avatar
87beater
I plan to run the Bilstein's as well. I've heard nothing but good things.
Old Aug 17, 2016 | 12:22 PM
Ginther's Avatar
Ginther
What year is your truck? I assume 99-04... How many miles? Diesel?
I ask because depending on how much the stock springs were sagging below stock specs.... versus where it sits now.... versus where it was supposed to sit.
I ran those ProComp 22210 springs on my 2004 diesel. It lifted the front about 3.5 inches from where it was sitting. But it was sagging due to age/mileage. Actual lift over the stock height (without sag) was only about 2".
So if you get some +2 inch shocks you should be good to go. Or measure from bolt to bolt with the shock removed and buy some that fit in that range.
I ran Rancho RS7000MT shocks on my 2004. They worked well. Dont recall the exact part number though.
Old Aug 17, 2016 | 03:55 PM
Long Haul's Avatar
Long Haul
When I bought my truck used it had Pro Comp shocks (not sure what model) and a Ready Lift leveling kit of some sort..
It rode terrible and the handing was really bad....Now they may not have been a top level Pro Comp shock, whatever they were they were bad..
Running Carli and Fox now no complaints..
ChiefGeek
Jun 14, 2023 04:36 PM
al4464
Jul 10, 2019 10:17 AM
SGorman13
Apr 17, 2012 07:01 PM
specialK4464
Jul 29, 2011 12:48 PM
w-i-l-l-i-e
Jun 17, 2006 06:52 AM
