Code P0475 Exhaust Pressure Control Valve
Old Mar 13, 2016 | 05:34 PM
oldboots1950's Avatar
oldboots1950
I have this sensor unplugged.
Is there a way to defeat this sensor so I don't pull this code?
Old Mar 13, 2016 | 05:58 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You can use a 470 ohm 1/2 watt resistor like I did in this thread.
https://www.ford-trucks.com/forums/1...cuum-line.html
You can use the EBP pigtail from RiffRaff.
EBP Pedestal Actuator Isolator Pigtail for Ford 7.3L 99-03
Old Mar 13, 2016 | 06:21 PM
oldboots1950
470 ohm resistor
Thanks for your help. I already ordered some from Amazon.
Old Mar 13, 2016 | 07:49 PM
Sous's Avatar
Sous
FTE Emeritus
The resistors worked, and have been working great for me on the EBPV and wastegate solenoids.
raptor05
Nov 30, 2006 07:21 PM
masterc16
Sep 18, 2006 12:49 PM
GB04
Dec 20, 2005 05:49 PM
bigdieseldav
Feb 17, 2004 04:30 PM
