Advice needed on P0478 code
Old Dec 20, 2005 | 05:00 PM
GB04's Avatar
GB04
Unhappy Advice needed on P0478 code
Twice over the past month, I have tripped a P0478 code (Exhaust pressure control valve high circuit input). I have no idea what to do to fix it.
I also want to know if its safe to drive long distances with this happening. Can I damage the engine, or the turbo ?
Old Dec 20, 2005 | 05:49 PM
stroker2's Avatar
stroker2
From Steve baz site:
0478 EPR Exhst press control valve high input Excessive back pressure - run mode Plugged sensor line, stuck butterfly, restricted exhaust
I'd say disconnect your EBPV(exhaust back pressure valve). Make sure it's fully open and you'll be fine. It's OK to drive it with this disconnected. Many people disconnect it just to get rid of the noise during engine warm up. Probably the tube from the front of the passenger side exhaust manifold going up to the top of the engine with the EBP (exhaust back pressure) sensor on top of it is plugged with soot, etc from the exhaust.
HKusp
Jul 30, 2021 04:44 PM
TerranE
25
Nov 23, 2016 11:17 AM
scline74
Nov 9, 2015 08:43 PM
VRC9170
Nov 7, 2015 10:04 PM
Riversonly
Mar 1, 2015 05:25 PM
