460 oil pressure issues after oil change
Old 03-13-2016, 12:58 PM
rolley76's Avatar
rolley76
rolley76 is offline
So took my truck to shop for free tire rotation and decided get oil change while there. After they drained oil they notified me they only had 5w 30 high mileage oil after I told them I wanted 10w40. They assured me would not make much of a difference. After 5 miles lifters started ticking. Took back to shop they put full syn additive in and sorta suited down. I headed home after. 3 miles later no oil pressure all lifters clattering shut truck off pulled over and towed. Once home started truck to move and oil pressure back. Next day took oil and filter off put 15w 40 rotella in. Started test drive 15 miles no tick good pressure thought all was well. Next day drive 20 miles lifters start ticking, progressing into clatter still have pressure. Turn around head home again and pressure starts bouncing then come to stop pressure stays up. What happened.?
Also this motor never made a tick or knock since I bought it 15k miles ago. Any help be appreciated. Thank you.
Old 03-13-2016, 02:03 PM
88n94's Avatar
88n94
88n94 is offline
You said you took the filter off. Did you swap out the filter for a different one?
Old 03-13-2016, 02:05 PM
rolley76's Avatar
rolley76
rolley76 is offline
Yes it was Napa proselect. I bought a wix 51515 replaced it.
Old 03-13-2016, 02:34 PM
rolley76's Avatar
rolley76
rolley76 is offline
New update!
Started and let truck idle and revved it quite a bit pressure back clatter gone. I'm stumped. What do I do next?
Old 03-13-2016, 03:14 PM
88n94's Avatar
88n94
88n94 is offline
If it continues to act up after driving it more, I would be inclined to swap out the oil filter for a Motorcraft. Wix makes NAPA filters, so you may have had one and the same.
I remember about 1975, my dad had a NAPA filter on a '67 Galaxie with a 289, and the oil pressure light came on and you could let it set and then drive it a ways before the oil light would come on again. I have no idea if NAPA filters were made by Wix at that time. Just a thought.
Old 03-13-2016, 03:18 PM
rolley76's Avatar
rolley76
rolley76 is offline
Ok, I got wiz cause on another thread that's ones everyone saying to run. I guess proselects are lower quality filter than Napa holds and wix. I have mach gauge putting on later. See what happens.
Old 03-13-2016, 07:26 PM
rolley76's Avatar
rolley76
rolley76 is offline
Ok I have 60 psi on start up and idle. 5 miles down rd losing it all maybe 5 psi. That's it
Old 03-13-2016, 09:36 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Change the oil and filter back to 10w40 and see what happens. 5w30 vs 10w40 shouldn't make that much of a difference at all, unless your main bearings/oil pump were already very marginal and on borrowed time.
Old 03-13-2016, 09:45 PM
rolley76's Avatar
rolley76
rolley76 is offline
I am thinking bearings are gone. That was my last plan before pulling it. Any thoughts on what engine to put in its place. Also looking at swapping zf5 in place of e40d. Any thoughts appreciated.
Old 03-14-2016, 12:51 AM
BalootheBronco's Avatar
BalootheBronco
BalootheBronco is offline
Why not just rebuild the 460 matched with a zf? You will need a zf from a 460, not sure if the 7.3 zfs will work.
Old 03-14-2016, 02:07 PM
bmxerbrett's Avatar
bmxerbrett
bmxerbrett is offline
Do you get the oil changed regularly? It sounds like you have some gunk in the oil pan that's getting stuck in the oil pick up filter in the oil pan. I would drop the pan and clean it out.
Old 03-14-2016, 06:34 PM
rolley76's Avatar
rolley76
rolley76 is offline
Not sure if anyone cares or reading this but today drained oil and strained through coffee filter. A lot of carbon coming out still no metal. So decided to add two quarts diesel ran twice in two minute intervals. Drained that all out still lot carbon. Now letting soak over night with 6 quarts diesel trying to get screen cleaned out I guess. Big project to get pan off. Trying this first. Anyone ran into this before and tried what I am. Just curious if will work.
Old 03-14-2016, 07:40 PM
dixie460's Avatar
dixie460
dixie460 is offline
Diesel fuel is good stuff but I suggest automatic transmission fluid instead. Replace one quart of engine oil with one quart of the trans oil and drive it for a bit.
Old 03-15-2016, 09:55 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
I agree with tranny fluid. Diesel isn't thick enough to build proper pressure...if you have carbon draining with your oil, someone really neglected oil change intervals.
Tioga 24
05-04-2024 06:16 PM
improvement54
15
12-30-2022 02:41 PM
tarheelgwb
2004 - 2008 F150
11-20-2012 05:06 PM
Scoarch
11-16-2012 06:02 AM
Michael Littman
09-03-2006 02:22 PM
Quick Reply: 460 oil pressure issues after oil change
