Accelerator Assembly
Old Mar 12, 2016 | 10:25 AM
Gigemags05's Avatar
Gigemags05
1947 half ton.
I need an entirely new accelerator assembly. What all parts will I need?
I have found an accelerator pedal:
Ford - Ford Accelerator Pedal - Original Type - Ford Pickup Truck | 21A-9735-A - Macs Auto Parts
and an accelerator rod:
Ford Accelerator Pedal Rod - From Gas Pedal To Linkage - Ford V8 Passenger | 48-9727 - Macs Auto Parts
and then there is also this spring:
Ford - Ford Accelerator Spring - On Linkage At Firewall - Ford Pickup Truck | 48-9737 - Macs Auto Parts
Do I need all of these parts? Will a universal throttle cable work? What else will I need?
How does it all connect? I am starting from scratch.
Old Mar 12, 2016 | 10:42 AM
Gigemags05's Avatar
Gigemags05
Another unrelated question:
My truck only had a door lock cylinder on the passenger door? Is that normal?
Can I add one to the driver side door?
Old Mar 12, 2016 | 11:40 AM
Tedster9's Avatar
Tedster9
Yes, that is normal for the time.
Old Mar 12, 2016 | 01:16 PM
Gigemags05's Avatar
Gigemags05
hmm, weird. Any idea as to why? How would you lock the driver's side?
Old Mar 12, 2016 | 01:24 PM
Rickster800's Avatar
Rickster800
Does your truck have the accelerator linkage similar to this still attached to the firewall? You will need this, or some other type of custom made system.
Old Mar 12, 2016 | 01:28 PM
Rickster800
As for the door lock, they were only installed on the passenger side during those years. To lock the driver's side door, you pushed down on the door handle, then crawled out the passenger side to use your key to lock the door. Some versions of Ford trucks also had a steering column lock. You used the key to lock the steering wheel instead of, or in addition to, locking the doors.
Old Mar 12, 2016 | 01:36 PM
Gigemags05's Avatar
Gigemags05
No, it doesn't have anything like that that I have seen. There was a mechanism attached to the firewall that I still have, but nothing like that.
Any idea what would be the best way to go about getting a linkage set up?
Old Mar 12, 2016 | 03:27 PM
Rickster800
Since you have a 1/2 ton, would probably need to know the engine you have...original flathead V8 or Inline 6...or something different. The linkages may be slightly different...example: how arms are bent to link to carb. I see them for sale on eBay from time to time.
Old Mar 12, 2016 | 03:31 PM
Gigemags05's Avatar
Gigemags05
Engine is a 351w so this may need to be fairly custom.
Would one of those universal pedals and throttle assembly be easier you think? I would like to keep the original, but that may not be feasible.
Old Mar 12, 2016 | 03:41 PM
Rickster800
I have not tried anything other than the original set up. I just found this linkage on ebay that is exactly what I have on my trucks. Since the cabs are the same from 1/2 ton all the way up to larger trucks I don't know why this wouldn't work for you. It says 1932 but if you look farther down you will see 1946 & 1947 listed
Vintage Flathead Ford Spoon Throttle Pedal w Mounting Cup Model A 1932 Hot Rod | eBay
Old Mar 12, 2016 | 03:43 PM
Rickster800
Just saw that you have a 351W. The throttle linkage attaches on the driver's side of the carb on that engine. A custom linkage of some type may be your only option as the original linkage is more suited for a passenger side design like on the flatheads.
Old Mar 14, 2016 | 12:28 PM
Gigemags05's Avatar
Gigemags05
My accelerator Assembly wasn't that style. It is floor mounted like the one I linked. Is that not factory?
Old Mar 14, 2016 | 12:52 PM
46fordtruck's Avatar
46fordtruck
That one you linked to on Mac's site is not the original style. The one in the eBay auction is the original. The pedal is the same for 6 and 8, but the linkage is different. Sounds like somebody replaced your original
Old Mar 14, 2016 | 01:45 PM
Rust Wrangler's Avatar
Rust Wrangler
Can't help you with the catalog parts as I've not seen this type pedal used in one of these. Looking at the later assemblies after '47, looks like they may be more of what you'll need if you want to use linkage.
In the past I've gone with chevy cable assemblies pulled at the junkyard. They were very easy to make work, being practically a bolt up deal with possibly slight mods to the carb end mounting bracket, depending on the carb, and/or adjusting the length of the pedal rod to get a comfortable foot angle. They used a couple styles of firewall mounted pivot assemblies and pedals. Pedals came with the captive pivoting type and a hinged floor mounted type like you have. That may be something to consider for your project.
I like/need the door lock on the passenger side....keeps me from locking my keys inside
Old Mar 14, 2016 | 01:56 PM
tacomacream's Avatar
tacomacream
Make sure that you lock the passenger door with the key from the outside. If you lock the door with the inside handle and then shut the door the key won't work.
