Body leaning left
Body leaning left
Got my truck up on a drive on lift so that I could take some pictures and see why it is leaning left. A list of what has been done is as follows,new front down and forward springs from m f (Eaton) new front hanger bar left side, new spring pins all the way around,bushings. I hope that pictures help and come out ok.
This is driver side looking back(front of axle)
This is passenger side looking back.
Driver side looking forward
passenger side looking forward.
Yes the snubber is to be over the center of axle but that has nothing to do with why one spring is lower. Springs are down and forward so if one was put in backward the axle would be off as these are also centering springs to center the wheels in the fender. Thanks Dave for checking it out.
Hi Art
You need to find what is actually sagging. If it is the body or frame. Do some measuring from side to side from the same points on opposite sides of the frame to the floor. That should tell you if it is the frame. The frame might be ok, just the body mounts bad. Measuring from the spring parts to the floor on each side to see if that's where the issue is.. Good luck. Just gonna take some crawling around and measuring to see whats going on.
Larry
Larry
Larry good to here from you I was up your way last week to see the boys at Hammons. As far as sagging it is not the body mount as that would have nothing to do with the different measurement between the springs and bottom of frame. I am going to swap out springs and see if that does anything if not then maybe someone did something to the frame that I cannot tell. I do know that the frame horns were cut off then some others welded back on and they are not the same size frame horns for the bumper. If need be I will take it to a frame shop and see. First though I will swap the springs around. I wish that when I built the shop that I would of put in a spot for a lift the exercise I get from getting up and down I am told is good for me I think they are b sing me.
OK ! I swapped springs and the same thing. I lined them up and they are the same height and same length no surprise there. I was hoping that it was a spring but no such luck. The spot on the drivers side that looks as though there was some work is just a weld spot that someone tacked on it (the weld) does not go all the through. I am going to find a good frame shop and have it checked out but my way of thinking is that it would have to be bent between spring hangers for it to do what it is doing. I need all the frame guys to chime in . I need to find out how to make photo's smaller EH! Thanks to all.
Jghake
24
04-15-2018 10:33 PM
Fastcat314
1999 to 2016 Super Duty
04-22-2016 01:17 PM
turbill
02-11-2012 11:10 AM
Grabber
09-14-2007 12:31 AM
