Spring Leaf rear end - revisted
Old Sep 11, 2007 | 04:21 AM
Grabber's Avatar
Grabber
Hi guys posted a while back with thoughts on the short rear end and springs, here is a couple of pics which i have remounted the spring perches and fabbed a new cross member for the front spring perches, and rewelded and boxed certain areas that the previous guy had butchered - could i get your thoughts on a few issues, General thoughts on the setup and what else i could do by adding bars etc?, and where should i mount the shocks and support member for them ? front of diff? rear of diff ?etc
Old Sep 11, 2007 | 07:36 AM
mechmagcn's Avatar
mechmagcn
Looks like with very little suspension flex, those springs and shackles are going to bottom out on the crossmember and bind. I would look at the possibility of turning the shackles down and mounting the axle above the springs. On the subject of shocks, I would mount a crossmember just to the rear of the axle to mount the shocks to.
Old Sep 11, 2007 | 10:30 PM
Grabber's Avatar
Grabber
Thanks Jeff, all good ideas and i do like the idea of the housing sitting above the springs, like my other Fords , but what other reason other than safety would this change make?? thanks for the reply
Old Sep 11, 2007 | 10:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Jeff is right, the shackles are way too close to the crossmember. The c'member really ought to be completely below the spring.
The boxing is good but should include the arch over the axle. That is the weakest point.
Nice looking work, tho!
Old Sep 11, 2007 | 10:53 PM
Grabber's Avatar
Grabber
Are you referring to the rear shackles? sorry im in stupid mode.
Old Sep 12, 2007 | 05:33 AM
49willard's Avatar
49willard
Yes, the rear ones. As the load increases on the rear of the chassis or on a bump, the distance between centers on the spring lengthens. I would look at moving the rear crossmember back to provide more room for spring eye to eye length changes.
Is this the same truck that was the subject of a lot of effort to gain possession of?
Old Sep 12, 2007 | 08:03 AM
Grabber's Avatar
Grabber
Now i got it , i see your point thanks for pointing that out, ill do so more work , yes thats the truck ,sounds like you know it well
Old Sep 14, 2007 | 12:31 AM
Grabber's Avatar
Grabber
Guys thanks again for the advise ive made the changes and it definately looks more solid, the frame currently is dead even from front to back, and the rear may need a addition of another leaf, but im more than happy with the end result, just need to work out the shock size and length and weld on some shock mounts and crossmember, Do the shocks have to be at any suggested angle? and here are some pics . Thanks for the replys
ljfen
Mar 10, 2013 10:47 PM
J_C
2004 - 2008 F150
Jul 12, 2010 08:33 PM
FordF350Baby
28
Apr 14, 2008 06:49 AM
DirtysouthZ71
Offroad & 4x4
Mar 1, 2004 09:38 AM
