1970 f100
Old Mar 9, 2016 | 08:32 PM
jsunt27's Avatar
jsunt27
1970 f100
I just put in headers but it seem like i need some more clearance on the cross member. the collector of my headman headers is touching there. I was thinking about raising my motor and tranny up? whats the best option for me?
Old Mar 9, 2016 | 08:41 PM
HIO Silver's Avatar
HIO Silver
What engine? What trans? 2wd or 4wd?
Old Mar 9, 2016 | 08:50 PM
jsunt27's Avatar
jsunt27
shoot forgot to mention that
It has a 302 and is 2wd and c4 trans
jsunt27's Avatar
jsunt27
and a c4 trans
Old Mar 9, 2016 | 08:56 PM
HIO Silver's Avatar
HIO Silver
Thanks.
Are the headers new and What make & PN are the headers? Or were they purchased used? It's sometimes a box of chocolates with the latter...
Long tubes will typically point directly at the crossmember and require that the exhaust tubing go up and over a short distance.
How about posting a pic and showing us what yer working with.....?
Old Mar 9, 2016 | 09:03 PM
jsunt27's Avatar
jsunt27
Thanks.
They were bought off craigslist but the part number on them is 89150 which matches the vehicle and engine i have. they are full length headman headers also.
it only needs about .5-1 inch of vertical clearance to make it over the cross-member.
So im kinda in a bind....I was thinking spacers under the trans/engine mounts to get the clearance i need. (i wont be able to get a picture up tonight though)
Old Mar 9, 2016 | 09:35 PM
HIO Silver's Avatar
HIO Silver
Shimming/spacing the engine and trans is not the right way. .. that'll likely cause other problems.
Just have a section of tube bent to go over the x-member... I don't suppose you have or know anyone that can weld and help you out....
Old Mar 9, 2016 | 11:24 PM
351Cleveland C4's Avatar
351Cleveland C4
Bend the headers....
Old Mar 10, 2016 | 06:59 AM
jsunt27's Avatar
jsunt27
Now how would I go about doing that I need the collector of the headers to go up about an inch and a slightly to the center of the engine this is for the passenger side and the driver side needs to go up about a half an inch. I'm not real sure why the headers are like that they were made for this engine I just need to fix the problem
Old Mar 10, 2016 | 09:26 AM
fe390pc's Avatar
fe390pc
I hear your frustration, this is a common problem. Most people here clearance the cross member. You can see pictures in several posts on here if you search.
Old Mar 10, 2016 | 01:38 PM
f100today's Avatar
f100today
Is the Trans mount in the correct location? If it is wrong or too low it could cause the engine to tilt down too much which would cause headers to hit.
Old Mar 10, 2016 | 03:41 PM
jsunt27's Avatar
jsunt27
Do you think it's possible that my trans mount could be so worn out that it's dropping the trans down a little bit which makes the headers hit on the crossmember?
Old Mar 10, 2016 | 10:03 PM
bmuhlbach's Avatar
bmuhlbach
Old Mar 11, 2016 | 12:06 AM
GaryKip's Avatar
GaryKip
Somebody always has the answer on this forum!!!!!
Old Mar 11, 2016 | 07:16 PM
jsunt27's Avatar
jsunt27
Man I so would but the collected basically butts up against the cross member:/
