Flaring Brake lines???
Use a small tubing cutter to get a square cut.
Deburr the cut end, both inside and outside.
Don't forget to install the fitting over the tube..!!!!
Now spray the die and tube with WD-40 (or equivalent) before double-flaring.
Practice makes perfect. Even a low-buck kit from AZO will do the job.
I got my brake tools and supplies from Speedway Motors.
AGS Nicopp Brake Line Coil 3 16" O D x 25 Foot | eBay
When you put the tubing in the flaring bar, you want the end of the tube to stick up the same height above the flaring bar as the thickness of the 'step' on the side of the double flare button.
Insert the double flare button into the end of the tube. Be sure to get the flaring yoke centered over the flaring button/end of the tube and compress the flaring yoke until the button bottoms out against the top of the flaring bar. It's OK to crank down with a fair amount of force on this 1st stage of the double flaring process.
Remove the button and recenter the yoke over the end of the tube. On this 2nd stage, DO NOT CRANK DOWN HARD WITH THE YOKE. You just want to get the 2nd stage of the double flare 'well formed.' Final compression of the double flare should come when you tighten the line into the caliper/wheel cylinder, flexible brake hose, brake valve or in the MC ports.
I've made a fair amount of brake lines in the past 30 or so years and no one showed be how to do it (I wasn't born knowing how to bend or double flare tubing. I just figured it out by fooling with it).
I don't use any lubes on the flares when I'm making them. If you do use any kind of lubricant, I would suggest using a dab of brake fluid on them. DOT 3, 4 and 5.1 brake fluid is synthetic-based and not petroleum-based. (DOT 5 is silicone brake fluid --not compatible with DOT 3, 4 and 5.1).
The seals inside the various brake components are not tolerant of petroleum-based oils/lubricants. If it comes in contact with them, they will swell and rupture, leading to a brake failure, potentially of the worst magnitude.
From 1984 to 2009, I had an Imperial-Gould manual flaring bar (pictured in the following photo).
I used to have one of those El cheapo 3-in-one tubing benders. It didn't take long before I pitched it and got some real (quality) dedicated benders. By "dedicated," I mean each tubing bender only bends one diameter of tubing. The 3 silver benders, left to right, are Imperial brand 3/8", 5/16" and 1/4" benders. The black bender is the one I use the most. It's a Rigid brand for 3/16" brake tubing.
....I still have the manual flaring bar but, it pretty much got retired in 2009 when I bought this Mastercool (p/n 71475) hydraulic line flaring/double flaring set. --makes production-quality flares each and every time.
Making your own lines isn't that difficult. A little bit of practice and in no time you can make nice lines too.
Thanks for sharing, I am motivated to do a better job next time, and to buy some good tools. Thanks UR
Baja
I can also almost always tell when someone hand forms a line instead of using a bender. You don't get the crisp, tight professional looking bends by hand forming.
I caught the Mastercool flaring set on sale. I got it for $289.00 and free shipping at the time. That set was worth it even if it had been at a higher price.
Name the sticky well Steve and it will get hit zillions of times people Google,Bing,etc. in the future.
