Low/high sides almost the same
Old Mar 8, 2016 | 06:06 PM
dman776's Avatar
dman776
Hi guys, first post here.
2000 Ford Expedition
AC had not been working for a year or so. I had tracked a leak down to the evaporator. Also, I had a very slightly noisy compressor/clutch.
I finally got around to pulling the dash, replacing the evap, accum, orifice tube, blend door, and heater core.
Got it all back together. Pulled a vacuum to 26psi or so.
tried to load in some R134a and I see the following:
low side - 110 psi
high side - 110 psi
after a few mins, i see the ac clutch kicking in for about 5 secs at a time.
The high side pressure goes up by 5psi (115psi or so) then back to 110psi when the clutch disengages.
Since the system sat so long without a charge (12mos), could the compressor have failed (seals)?
Any ideas?
Thanks for your patience.
Darryl
Old Mar 10, 2016 | 12:30 AM
Torky2's Avatar
Torky2
Vacuum is measured in inches of Mercury, or Microns. If you meant 26" of Mercury, that's a poor vacuum. If you were at the top of Mt. Everest, though, you could go with it
low side - 110 psi
high side - 110 psi
Any ideas?
Internet is imperfect, we can't see exactly what you did, and what you may have missed. How about a cockpit error?
Hi-side side wheel valve not closed tight on manifold gauge set?
Orifice Tube not installed?
Orifice Tube installed minus the O-rings, or rings displaced because lubricant not used when inserting tube?
Kschab123
22
Jul 23, 2019 01:51 PM
Phoenixfla
Jul 20, 2017 10:36 AM
srwven
17
Jun 18, 2017 01:20 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Aug 18, 2013 06:58 PM
hogdogs
Jun 30, 2008 09:15 PM
