Engine Shutdown With Pushing Brake Pedal
Old Mar 6, 2016 | 02:04 PM
dirtbikeflyboy917's Avatar
dirtbikeflyboy917
Hi,
What device could I install on my diesel and gas vehicles where I can keep it idling, but if someone jumps into steal it, and presses the brake pedal, the engine shuts down. I can't for the life me think of what they are called, but I remember seeing them in the past.
Thank you.
Old Mar 6, 2016 | 03:11 PM
Franklin2's Avatar
Franklin2
Didn't know they made such a thing you could buy off the shelf. You could easily make one with a relay and a arm/disarm switch mounted somewhere. You would have to pick the correct wire to shut the engine off, which would vary depending on the vehicle.
Old Mar 6, 2016 | 03:17 PM
dirtbikeflyboy917
Hi,
I know some companies used (and may still) to make devices for that purpose. I'll look into the custom option. Thank you.
Old Mar 16, 2016 | 06:53 AM
RightWingNutJob's Avatar
RightWingNutJob
An aftermarket remote start system would give you this functionality. Although, some of them will shut the engine down after a certain time period (15-30 minutes?) to prevent excessive idling.
Old Mar 17, 2016 | 06:47 AM
projectSHO89's Avatar
projectSHO89
Go read this thread, this subject was discussed in depth.
https://www.ford-trucks.com/forums/1...ng-button.html
Snapon90
Apr 12, 2019 11:42 AM
Spoojr
Dec 26, 2016 08:26 PM
jfmaz
2004 - 2008 F150
Feb 9, 2010 02:20 PM
Torstein
Apr 27, 2003 04:20 PM
