Please read i need help
Old Mar 6, 2016 | 12:19 PM
78 F350 RANGER 7.5L's Avatar
78 F350 RANGER 7.5L
Exclamation Please read i need help
So long story short I've recently acquired a 78 RANGER F-350 and replaced the starter solenoid now the truck won't start at all a am a total NEWBIE to not only this forum but mecacnics as well can some one please let me know what all the wires are for there are 2 on the post that connects to the battery 2 in the middle and 2 on the opposite side going to starter motor I almost had it started when I noticed smoke coming off the negative battery terminal/wire.
Old Mar 6, 2016 | 12:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 78 F350 RANGER 7.5L
So long story short I've recently acquired a 78 RANGER F-350 and replaced the starter solenoid, now the truck won't start at all.
I am a total NEWBIE to not only this forum but mechanics as well. Can someone please let me know what all the wires are for?
There are 2 on the post that connects to the battery, 2 in the middle and 2 on the opposite side going to starter motor. I almost had it started when I noticed smoke coming off the negative battery terminal/wire.
You have posted this question in the wrong forum, this is for 1980/86 F100 and larger series trucks.
You want the 1973/79 F100 and larger series trucks forum.
Old Mar 6, 2016 | 12:26 PM
ctubutis's Avatar
ctubutis
OK, I moved this thread to the 73-79 forum.
Old Mar 6, 2016 | 12:35 PM
78 F350 RANGER 7.5L
Thanks guys I apologize. Is it correct that the thread was moved to the correct forum I couldn't figure out where to find it
4x4slik's Avatar
4x4slik
http://www.fordification.net/tech/im...ster_3of10.png
Here is a link to a wiring schematic for your truck. The only thing that should be on the starter side is the starter wire.
Old Mar 6, 2016 | 12:37 PM
NumberDummy
Thread was moved by Chris (ctubutis), moderator of the 1980/86 forum to the 1973/79 forum.
Old Mar 6, 2016 | 01:02 PM
phlegm's Avatar
phlegm
Smoke or spark from a terminal typically means you need to clean and tighten that cable end.
Old Mar 6, 2016 | 04:29 PM
78 F350 RANGER 7.5L
By chance can you tell me what is supposed to be hooked up where the battery wire connects to the solenoid. There is another wire that someone told me is a fuaible link ??? And it's currently conected to the solenoid with the positive battery wire
Old Mar 6, 2016 | 05:09 PM
brown79's Avatar
brown79
Bat positive-solenoid side closest to bat. Along with the other wires that have large ring terminals.
Other side of solenoid to starter
Red (usually) small wire to small terminal on sol marked "s"
Brown (usually) small wire to small terminal on sol marked "I"
Battery negative to the engine block
phlegm's Avatar
phlegm
I attached a picture of mine.
Heavy red wires.
One from battery
One to starter.
The terminal closest to the battery side of the solenoid is the one you have to jump to engage the starter.
Anything connected on the battery side should be on a fuse or a fusible link.
Sorry I can't go into more detail, but I'm in the middle of a 4 wheel brake job.
Old Mar 6, 2016 | 05:24 PM
78 F350 RANGER 7.5L
Heavy red wires.
One from battery
One to starter.
Thank you will update when I do it
ashzeigler
May 18, 2014 07:09 AM
jtipton331stroker
Dec 29, 2011 11:25 AM
ford racer 02
Jan 15, 2006 07:09 PM
djkj
Oct 28, 2005 10:11 PM
Candace1977
1983 - 2012 Ranger & B-Series
May 11, 2004 11:12 PM
