Glow Plug Resistance
Old Mar 8, 2016 | 09:54 AM
Walleye Hunter's Avatar
Walleye Hunter
I used the block I can't remember exactly where but knowing how I operate I probably used one of the holes from the VC bolts. They're clean, accessible and right near the glow plug so there is less chance of anything going wrong.
Old Mar 8, 2016 | 11:46 AM
1L243's Avatar
1L243
Can't say what's typical. The link I posted earlier says most good glow plugs will read between .01 and .05.
7.3L IDI Glow Plug Troubleshooting
The consensus on the forum is anything under .2 is good.
I tested both sides several times, I grounded at the negative battery terminal.
Drivers side front to back was .06 .05 .05 .05 Passenger side .02 .02 .03 .02
I will add that my GPR is not working. After I replace it today I am going to retest the glow plugs after they have had a chance to cycle a few times and see that they read..
Old Mar 8, 2016 | 06:44 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
It is not "The consensus on the forum is anything under .2 is good.", it is anything under 2. They don't have to be close to each other either, it is not like compression testing, as long as they are under 2 ohms of resistance they are good.
Old Mar 8, 2016 | 07:27 PM
1L243's Avatar
1L243
yes, important to put the decimal in the right place my fault...
the_auto_tech
Aug 21, 2013 08:45 AM
sullyt28
Jul 27, 2010 07:38 PM
idahodisco
Mar 24, 2010 08:47 PM
2coolcars
Nov 14, 2006 05:54 PM
