3 and 6 glow plug failure
Old Nov 13, 2006 | 07:58 PM
2coolcars's Avatar
2coolcars
Hi I have a 2000 7.3 ford Excursion and I replaced the glow plugs about a year ago and now the service engine light is on and it says that 3 and 6 glow plug circuit failure. Is there a way to check the glow plugs. I also am not sure of the cylinder orders to locate three and 6. Is 2,4,6,8 on the drivers side starting at the front of the motor and 1,3,5,7 on the passengers side. Is there any other common problem in the wiring going to the glow plug. thanks
Old Nov 13, 2006 | 09:54 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved, I think you'll have more luck in the 7.3 forum
And WELCOME to FTE!
Old Nov 14, 2006 | 05:04 PM
cookie88's Avatar
cookie88
FTE Emeritus
Welcome to FTE 2coolcars.
The cylinders are numbered as you described them. The four outside wires on each valvecover harness (the brown ones) go to the glow plugs. You can ohms check the plugs and UVC harness without removing the valvecover.
Seeing as you are getting an DTC from the glow plug system your glow plug control module (GPCM) might be at fault.
Old Nov 14, 2006 | 05:44 PM
2coolcars's Avatar
2coolcars
Thanks for the info Scott I appreciate it and I will try that. If the actual glow plug was bad would the service engine light come back on right away after I erase the glow plug fault in the computer because mine dont come back on for a couple days. Thanks Mike
Old Nov 14, 2006 | 05:54 PM
cookie88's Avatar
cookie88
FTE Emeritus
Possibly. Most malfunctions have to be recorded on consecutive drive cycles to trigger the SES. I'm mostly guessing on the GPCM, only California F-trucks and excursions have them. For the rest of us the glow plugs will never trip the SES as the only thng monitored by the PCM is the "on time" of the glow plug relay.
