Engine Knock...
Old Mar 11, 2016 | 07:07 AM
firebus's Avatar
firebus
UPDATE:
First, Thank you Mr. Chan for suggesting Randy. Great guy, great work
So number 8 injector was making the noise, however number 2 actually had the performance issue and threw off the balance. Number 2 was replaced, and so far no noise from number 8. Of course that number 8 replacement may be in my future.
Anyway, thanks to all that commented.
PS- also confirmed that the bearings in my diff. are noisy. but that's another adventure..
Old Jun 7, 2016 | 12:54 PM
fx10mtx's Avatar
fx10mtx
Knocking sound
Hey firebus!
Would like to know if your problem has been solved with this repair?
I have the same sound on my truck.
Dealer had the truck twice for a week in the shop and can't get a diagnostic...
Since injector has been replaced, have you hear the knocking sound again?
Thank you!
Old Jun 8, 2016 | 08:17 AM
firebus's Avatar
firebus
Originally Posted by fx10mtx
Hey firebus!
Thank you!
Well, yes and no. So I didn't not have an engine light on, With the Ford diag. tool, he turned off one injector at a time. When he came around to number 8, it was clear as day that 8 was making the knock. HOWEVER... When doing a balance test (same diag tool) Number 2 was not performing properly, while number 8 was performing, but noisy.
So in the end, we replaced number 2, and find that number 8 is quieter, but not perfect. So I should probably replace it as well at some point. I did find that it was quieter when using the Motorcraft Lubricity fuel additive.
Bottom line, the tech can turn off one injector at a time, and you will know it when it shuts up..
Hope that helps, reply back when you get it sorted. BTW, how many miles on yours?
Old Jun 8, 2016 | 10:54 AM
fx10mtx's Avatar
fx10mtx
Thank you for your reply! Mine has only 68,000km. I'll let you know what they found, truck is in the shop since monday 😉
Realgraverobber
1997 - 2003 F150
May 9, 2018 01:07 PM
creator
25
Feb 5, 2012 07:21 PM
Rick Wallace
Aug 22, 2010 01:14 PM
Bigfwt04
21
Dec 17, 2008 10:52 AM
WilliesSD250
Jun 2, 2006 11:58 AM
