T18 won't shift
Old Mar 27, 2012 | 12:50 PM
mcampbell545's Avatar
mcampbell545
T18 won't shift
My T18 tranny in my 85 F150 will not shift, first instinct was clutch but after tearing the drivetrain out of the truck to check the clutch, there is virtually no wear on it. Slave cylinder is leaking a littttttle bit but the mechanic that took a quick look at it said it was still working. She was shifting fine when i left for school, then when i got off the highway i couldn't shift. Help anyone??????
Old Mar 27, 2012 | 10:59 PM
85e150's Avatar
85e150
Check your firewall for flex and a crack where the clutch master mounts. Check all the rest of the clutch set up and make sure the motion at the pedal is getting to the throw out bearing.
Next is to pull the top off the trans and see if there is something wrong with the shifter and forks. You should have a removable panel in the floor of the truck so you don't have to pull the box.
85GT5.0
Jul 15, 2009 08:13 PM
marine39
1997 - 2003 F150
Jan 12, 2007 04:33 PM
Blownpiston
1983 - 2012 Ranger & B-Series
17
Jul 19, 2006 11:25 PM
fordtruck88
Aug 28, 2005 10:09 AM
heysteve
Jun 4, 2003 09:28 PM
