Sponsored by: Real Truck
Less Than Level
Old Apr 27, 2016 | 11:30 AM
  #31
wrvond's Avatar
wrvond
Originally Posted by EDC8008
I have mine at 10 too 15 empty and it is a little better. I put a load control valve in the cab hooked into an onboard compressor but also kept manual fills only put them inside the fill door.
I was going to put mine behind the fuel door, but didn't see a good way to route the passenger side tubing without crossing too close to the exhaust for my liking. Also decided I didn't want to drill through metal. Ended up putting a single valve next to the license plate. Did have to buy an extension cord for my air pump in order to reach the power port under the back seat.
Old Apr 28, 2016 | 09:18 AM
  #32
EDC8008's Avatar
EDC8008
I ran the tubing through the support channel under the bed box after putting it in to a length of wire loom to protect from chaffing. Yea I had to think about drilling but then did. It just came up cleaner looking to me and if I had to add air it was just convienent
Old Apr 28, 2016 | 02:45 PM
  #33
wrvond's Avatar
wrvond
Good thinking with the wire loom. I have a bunch of that on the shelf. I have a bunch of it on the shelf because I always forget I have it in situations where I probably should use it...
l8000
All Things Towing
Jan 31, 2014 11:19 AM
chinook507
Sep 21, 2010 05:10 PM
coop3
Jul 13, 2007 07:26 PM
nater350
Jan 30, 2007 05:47 PM
MustangGT221
Jan 2, 2002 12:24 AM
