1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 6 liter super duty 4x4 problems
Old 03-03-2016, 01:51 PM
georay's Avatar
georay
georay is offline
i bought this truck last fall has 140k on it there been something wrong with the 4 wheel drive since i owned it just left in 2 wheel drive till i had time to repair it , when the 4x4 is engaged and under load it seems like the front hub drivers side clunking and slipping you can really feel it makes quite a noise and not just when turning straight up a hill will make it happen.
a friend with a similar truck though that i just mite need to clean and re grease hubs because not fully engaging, i'm thinking it's more than that, so looking for any help to identify the problem "hoping for the best expecting the worst"
thanks geo.
Old 03-03-2016, 06:34 PM
redford's Avatar
redford
redford is offline
Received 1,631 Likes on 955 Posts
Is this a manual or automatic 4 wheel drive system?
Old 03-04-2016, 06:25 AM
georay's Avatar
georay
georay is offline
automatic trans & locking hubs
Old 03-04-2016, 06:41 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
You just need to check the drive axle ujoints and the locking hub. I'm assuming you have manual hubs? Also the rear needle bearing in the main bearing..
Old 03-04-2016, 07:48 AM
georay's Avatar
georay
georay is offline
they are manual and auto
Old 03-04-2016, 08:01 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
That would be auto...can't mix the two. those hubs get funky for sure..
bublitz3
12-29-2014 06:42 PM
carysf250
08-04-2009 01:51 PM
Draft_Horse
11-29-2006 08:49 AM
rosco_p_coltrane
05-14-2006 01:45 PM
Chris_94_Ltd
12-07-2004 08:46 AM
Quick Reply: 2004 6 liter super duty 4x4 problems
