Dual MC, also I see on your build thread that you used Moog CC808 springs, are you happy with that model? What shock would go well with an 808.
Actually, what I was referencing is what style vacuum booster will you be using? --single diaphragm or dual diaphragm?
From left to right: '68 F250 single diaphragm booster, '74 F100 single, '74 F350 dual, '74 F350 dual, '79 F150 single.
View from the other side.
If you posted a picture of the booster you have, I could tell what it is.
The Moog CC808 springs work nicely. I don't have any fancy shocks, just a set of Monroe Gas Magnums all the way around. Handling was also helped quite a bit with the '78 F250 CS front sway bar and the '79 Bronco rear sway bar I installed.
