As long as the P.O. knows it's all in fun. As you noticed as well as Jeffafa that we emphasized on "BRAKES" in a fun way. Regardless of what we, or should I say "I" said, the most important thing to remember is, fix the "Brakes" no matter how it's spelled.
You are absolutely correct Robert. And to the PO, you just stumbled across an awesome bunch of people here in the Bumpside Kingdom of FTE. Welcome BTW. This may be a Tech forum but we like to Help people and keep it light. And fun. Kinda like when your Dad was teaching you something and you finally "got it". When your light bulb came on and you looked up at him, that wink he gave you is now us.
I appreciate all the reply's, I have started tearing into the wheels an I see why replacing everything is necessary, the wheel cylinders are packed with rust and crud and are busting open and everything else is so packed tight with crud i have no idea how they were working to begin with. this should be fun....
Glad to see you on the board. Sorry for the ribbing, that's just me.
As for brakes, your going to learn a lot about them. Stopping is the most important part of the vehicle in my opinion. I talk with a lot of people doing builds, most are young and eager to get started. They usually start talking about performance upgrades, when I ask about their brake's they say "The truck stops fine" they haven't touched them so they haven't a clue as to what's going on with them.
As I tell all who care to listen, if you have a stock setup, get it running right, then make sure it stops as it should. Make sure the vehicle is as safe as it's suppose to be. These trucks stop fine as a stock truck but there is maintenance involved. Remember these trucks were built when there wasn't as much traffic on the road as there is now. Upgrading the brakes to disc brakes sure helps, as I said earlier, the stock brakes work just fine as long as you drive it like it was built to be driven.
Any time you increase horsepower, you need to increase stopping power.
Read the information provided so far, replacing the rubber lines is a must and sometimes forgotten. Replace everything you can, 50 year old stuff does not last forever.
Finished up the rear brakes and the master cylinder is staying full now! So the major question would be, what is the Cheapest/best way to get discs on the front without a donor 70s ford? would buying a kit from scarebird (189.00), some dodge rotors(60.00), GM Calipers(100.00???) be the cheapest way to go? i estimate it would cost around 350.00? Am I missing something or is there a better rout to take?
Just out of curiosity, why would you not want to use a Dentside donor disc brake system that would be a direct bolt-on and have components from a single auto manufacturer, as opposed to a disc brake system that's going to require parts from three different auto manufacturers to put together?
I'm sure I have well more than $350.00 total invested in my front disc brake conversion ('69 F100 using a disc brake/I-beam setup from a '77 F100) but, I bought the '77 F100 disc brake donor parts ($125.00) then spread my cost out over time in buying the rebuild parts for it until everything had been gone through and was ready to be installed.
In the mean time, while I was refurbishing the donor parts, I still drove my truck with its all-wheel drums until the time came to swap it over to front discs. This approach gave me an essentially factory setup using parts from a single manufacturer and didn't kill my bank account in the process.
If you decide to to the kit thing, make sure that you make a folder with all the different part numbers and information. So when you (or the next owner) need to buy a part you don't look silly at the autoparts store. But I got my F350 set up off of a donor. I had never done that type of parts removal before. I printed off the pages (from HIO Silver's tech sticky) studied them, and took a box of tools to the junk yard. Other people in the yard there were coming by and asking me how to do stuff. It wasn't that hard! Just remember to work safe!!! If you don't support that truck correctly, don't expect a warning or "I sorry that I crushed your leg" from the frame.
Ultraranger, am I missing something as far as parts needed besides the dust shield, rotors, calipers and pads? Or does the spindle need changed as well? also I was planning on keeping the brakes manual.
Everybody has their own way or philosophy on how to do something or which is the 'best way'. I always recommend to change the ENTIRE front suspension parts over (I-beams, radius arms, spindles, etc. when putting a Dentside front disc brake setup on a Bumpside. This eliminates getting components mixed up that later leads to parts that won't connect and the aggravation that will ensue.
As far as donor rotors go, not really worth getting them since they will likely be worn/rusty. Brand new rotors are around $35.00 bucks ea. Calipers can be turned in as cores for newly rebuilt calipers along with new brake hoses.
It will also matter if you have manual steering vs. power steering in regards to tie rods, drag links, pitman arms and steering gear boxes.
I have manual steering, as well as manual brakes, does this mean that I can purchase a new set of rotors and calipers and slap them on? I feel like I am way underestimating this. Im just trying to get some better braking in the front end. also I have never converted brakes before.
Unless you've replaced the kingpins, kingpin bushings, I-beam bushings, the radius arm bushings, coil springs and shocks, since you've taken ownership of your truck, I don't see it as a good approach to installing disc brake components on existing Bumpside I-beams/radius arms. The brakes will only be as effective as the suspension components they're bolted to. If the suspension components are worn and sloppy, the the brakes will not be effective at (controllably) bringing the truck to a stop.
If you're going to pull the existing suspension apart to replace/rebuild these items, then it only makes the most sense to go ahead and install the rest of the Dentside suspension components, instead, that were actually designed for the disc brakes and its steering components and to help aleviate component incompatibility issues.
--the forward ends of the Bumpside radius arms are also not designed to accept the endlink brackets for a stock '75-'79 F100 - F350 front sway bar --if you ever had the notion to install one, like I have on my '69 F100 with a complete '77 F100 disc brake front suspension.
Im about to go to the salvage yard and pick up the brake booster, ms, spindles and brake setup, will putting the I beams (which seam wider) totally mess up my steering? or should I keep my I beams and just replace the kingpin? I wont be putting a sway bar on. I will replace the springs, and shocks when money is available.
Thank you all for you input, it has helped greatly.
What master cylinder do you recomend? also, is it best to just rebuild the kingpins while I am doing this? Also I assume this is the best time to do the I beam bushing and radius arm bushings.....
While the suspension is apart is the time to break the disc brake donor suspension down, clean it up and install new kingpin bushings/kingpins, I-beam and radius arm bushings.
I don't know what booster you're planning to use --single diaphragm or dual diaphragm? I can't give a good MC recommendation without knowing this first.
