Sponsored by: Real Truck
No running lights/dash/tail lights
Old Apr 18, 2012 | 08:18 AM
jhander's Avatar
jhander
Hello,
Went to leave for work yesterday and had no dash lights, running lights or tail lights on my '06 F250. Had headlights but thats it.... stopped and bought a new headlight switch but that turned out to not be the problem. All fuses seem to be ok...
Any ideas??
Thanks,
John
Old Apr 18, 2012 | 08:44 AM
redford's Avatar
redford
FTE Leadership Emeritus
I would start by going back and checking the following fuses very carefully.
2,7,18,34,35 and 41.
Old Apr 18, 2012 | 09:05 AM
jhander's Avatar
jhander
Will do, thanks for the reply.
Old Apr 18, 2012 | 09:18 AM
jhander's Avatar
jhander
Well no luck there...
Old Apr 18, 2012 | 09:12 PM
LaredoF350's Avatar
LaredoF350
My 2003 used to blow a fuse - cant recall but the #41 triggers a vague memory. Mine was a problem in the steering column and would blow the fuse from time to time when tilting the wheel - small wiring glitch was fixed and then no probs after that...
Old Apr 19, 2012 | 09:46 AM
jhander's Avatar
jhander
Went through the fuses again and found #15 was blown.....had some real high water the day before so I guess a little made it in somehow. Thanks for the help.
6.9idiatsturbo
18
Aug 15, 2016 05:54 PM
rpenterics
Feb 17, 2014 08:27 AM
ford390gashog
Dec 27, 2004 11:32 PM
