Questions about leveling kit install
Old Feb 29, 2016 | 09:44 AM
navistarnut's Avatar
navistarnut
I'm guessing some of this has been beat to death but just wanted to confirm a few things about doing a 2" leveling kit. Being it's an 03 it's pretty simple with the front leafs.
Guessing I need to upgrade the front shocks to accept 2" more travel?
Would folks also recommend at that time going to a dual cylinder stabilizer set up? Is the single factory good enough? I am going to replace it at any rate.
Thoughts on the track bar?
Old Feb 29, 2016 | 10:33 AM
WatsonR's Avatar
WatsonR
You don't need anything if kept under 3", the lift won't bother the shocks, actual distance they travel will be about 1/2-1" more.
I'm not even running a stabilizer and have a stock track bar.
install the kit... be done.
Old Feb 29, 2016 | 11:44 AM
navistarnut
Riddle me this Randy, since I was thinking of doing the shocks anyway, would be be wise to get some that are meant for a 2" lift?
Shocks are about due anyway and I was leaning towards either Bilstiens or Rancho
Old Feb 29, 2016 | 11:46 AM
bthr22's Avatar
bthr22
Subscribing because I'm curious too. About to do 2-2.5" and have Bilstein 5100s
Old Feb 29, 2016 | 01:30 PM
WatsonR's Avatar
WatsonR
I wouldn't spend the extra $$ on a shock designed for a lift when the stock shocks will work fine. I think you'll over pay for something you don't need.
Most shocks in stock form can handle up to a 3" lift without replacing the shock. They recommend replacement when going up 4" or more. Honestly, I don't think you'll find a shock labeled for a 2" lift, most say for a 2-4" lift.
You have the same leaf spring set up I do and the stock height Bilstein 5100 is a perfect fit. I've never bottomed them out or topped them by over extension. If it was required, I believe they would advertise it that way... "this kit requires a taller shock" or would be part of the kit, most 2" lifts say "compatible" with stock shocks.
I don't think I'd do a 2.5 lift either, then it will point to the sky and may even require a rear lift to even it out... goal is a level truck? There's a thread going now about 2.5" being to much.
Old Feb 29, 2016 | 03:20 PM
navistarnut
Appreciate the info. Yes, goal is level, the kit I am looking at is 2", no need to go more than that. Just sick of the *** end being higher than the front, and to add to this I barely have the clearance now with rims/tires we installed the other night.......265/60R20 Wranglers.
Tires are half tread and just touch the mud flaps when turned full stop on the inside, so when time comes for new tires, spells trouble. According to my eyeballing a 2" should address this.
Old Feb 29, 2016 | 04:02 PM
ultrasks700's Avatar
ultrasks700
I have a 2.5 zone on my 04. I added shocks because they really arnt that much and I figured with everything apart it was a good time to replace them. I think it was maybe 150$ for 4 of them. They are standard length. The adjustable track bar made install a breeze and the truck rides so much nicer now
17PlatinumSFL
Jul 18, 2020 06:02 PM
c delisio
Jan 8, 2016 04:41 AM
HarleyFXDL
Mar 2, 2009 11:21 PM
BigBlockGuru
Jul 29, 2004 09:40 PM
