Radius Arm Bushing Replacement
Old Aug 11, 2003 | 09:54 AM
My Ford Truck's Avatar
My Ford Truck
Need a little instruction here.
What parts need to be removed to replace the radius arm bushings on my '65 F100? They are in real bad condition.
Thanks!
Old Aug 11, 2003 | 10:35 AM
barry's Avatar
barry
No special tools are really needed other than basic sockets, wrenches. You have to remove the nut and washer off the back side and force the axle forward or unbolt the radius arm off the axle. You might have to get a coil spring compressor to compress the spring to take it out, so you have more room to move the axle forward or to unbolt the arm. I've seen the mechanics at the dealer I worked at use a long pry bar to pull the arm forward, but they also had the advantage of a lift to work on. You also need to get a front end alignment after you replace the bushings. Very important!
Barry
Old Aug 11, 2003 | 10:37 AM
barry's Avatar
barry
Almost forgot. Support the axle with a floor jack and make sure you have the truck properly supported on jack stands. Don't want to have an accident and drop the truck on you!
Barry
Old Aug 11, 2003 | 12:59 PM
My Ford Truck
Forgot to mention that I'm going to replace the front shocks at the same time.
Then I can get the alignment and new front tires!
Old Aug 11, 2003 | 07:05 PM
ddavidv's Avatar
ddavidv
If possible (and I don't know that it is), avoid removing the pivot arms (I beams). They can be real buggers to get back in.
You actually don't need a spring compressor. If you remove the retainer straps on the I-beams the entire assembly will drop down and completely release tension on the spring (and it will fall out).
You need one big-**** socket for the nuts though. It's 1 1/8".
Front shocks are easy.
Old Aug 12, 2003 | 01:42 AM
cashs66's Avatar
cashs66
Once you have detached the spring and shock, be sure to avoid letting the front axle drop to the point that it stresses your brake hose.
Old Aug 13, 2003 | 06:38 AM
William's Avatar
William
the socket is a 1/2 inch drive deep well. I suggest you consider replacing the I-Beam rubber pivots, King pins and radius arm bushings all at the same time. If the tierod ends are worn (yes they are) replace these as well. Not cheap but you will get another 30 years from it if you do this right. You will need a small floor jack, common tools and that deep well socket and braker bar. You can do this in steps if the budget is limited. Do one side at a time. Raise the truck, support it on a jack stand under the front frame horn, remove the wheel, unbolt the shock, spring retainer strap and lower the axle. The spring can be yanked out to allow you to use that deep well socket and unscrew the radius arm to I Beam bolt. Remove the cotter pin and unscrew the Radius arm pivot nut. Clean, paint and reassemble with plenty of anti-sieze compound. One side at a time is OKAY and you won't need a front alignment at this point. Post back and we'll discuss the next step.
Old Aug 13, 2003 | 07:12 AM
cobraguy's Avatar
cobraguy
Do it just like William says and don't forget to use lots of your favorite penatrant( WD40,Liquid wrench,One Touch).
Old Aug 13, 2003 | 11:46 AM
My Ford Truck
Thanks a million!!!
One more question. Will the radius arm from a 66' 250 fit my '65 100? (I think so) Reason? The lower mounting bracket for the right side shock is trash. The holes are oval and large. The radius arm, complete with a good bracket, on my ex-donor truck is still available to me at no cost and the entire arm might be easier to get than just taking off the bracket. If I'm wrong, please correct me!
Old Aug 13, 2003 | 12:38 PM
44dwarf's Avatar
44dwarf
The spindle is different I think as 250 has 6 or 8 lug and uses different bearings so you'd have to swap spindle and change king pins.
I think it be easy-er to grind off the rivet heads and replace the shock mount.
44
Old Aug 13, 2003 | 01:20 PM
My Ford Truck
Thanks!
I was just thinking about using the radius arm and not the twin i-beam exactly for that reason. I have to keep my 5 lug since I have rims for them. The 250 did use 8 lug.
Or would it be easier to take the entire assembly and put the 5 bolt spindle (part name?) on it when the kingpins are changed?
Suggestions? Remember though that this is my daily driver and I can't have it on blocks for a couple of weeks!
Old Aug 13, 2003 | 02:10 PM
44dwarf's Avatar
44dwarf
Oh thats right the shock goes on the radius arm. In that case yes it should swap but measure twice just to be sure.
If you have a welder you could just get two thick washers and weld them to the old worn out mount. Quick and easy.
44
reem98
15
Nov 15, 2023 06:08 AM
frodomonster
17
Oct 26, 2011 10:07 PM
kbak
Dec 21, 2006 06:03 AM
warema
1978 - 1996 Big Bronco
Dec 8, 2003 10:00 PM
lw2muddy
Jun 9, 2003 09:29 AM
