Voltage regulator question?
Old Feb 28, 2016 | 02:28 PM
sonny1965's Avatar
sonny1965
I have a 65 f100 sb 352 with a\c The new replacement regulators pins where the harness plugs in are thinner and are not as wide as the original one.The harness don't fit tight.Has anyone run into this before?
Old Feb 28, 2016 | 04:05 PM
daveengelson's Avatar
daveengelson
Just replaced the Volt Reg. in my 65, with the 390, purchased a cheap generic brand from local 'CarQuest', which I believe is now being purchased by Advance Auto Parts? I usually purchase replacement parts thru Napa; however, in this case decided to support local auto parts store, and friend. Best as I can determine, the male pins on the voltage regulator measure approx. 3/16" and the harness female receptacle are about the same, tight fit.
Old Feb 29, 2016 | 01:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1963/64 Thunderbird & 1965/80 all: The original alternator regulator had points and a black or blue painted cover.
In 1981, Ford replaced it with an electronic regulator that has a mostly flat aluminum cover with MOTORCRAFT on the diagonal.
The wires plug on without any mods.
Old Feb 29, 2016 | 02:10 PM
sonny1965's Avatar
sonny1965
Thanks for the help Dave and Number Dummy I will look a little closer and
check the wiring why the females won't hold the regulator in tight
daveengelson
Feb 22, 2017 02:10 PM
sleddog60
Aug 30, 2013 09:49 PM
AWBraschler
May 21, 2010 11:34 AM
GeneStoner
May 21, 2005 05:32 PM
superman64011
Dec 15, 2004 12:07 PM
