TS performance default code question.
Old Feb 28, 2016 | 02:02 PM
Xcelor8's Avatar
Xcelor8
I posted this in the tuner forum and I've got no help so far, I have to put the computer back in today, I'm trying to figure out if it's the correct chip or not. Unfortunately at this point In probably just going to put in back together without the chip unless someone is confident is the correct chip.
The chip is for a 02-03 excursion, I just have reservations that the codes are different for the computers.
I have a 03 excursion. auto
Old Feb 28, 2016 | 04:52 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes. The chip will work. The chip is for a California 02-03 F-series which doesn't have PATS. Therefore, your Excursion's Passive Anti-Theft System will no longer work but the glow plug parts and pieces will all function properly.
You will notice that your "THEFT" light will flash after installation of the chip. Not a big deal. The PATS module is located above the accelerator pedal position sensor and has a 4-wire green connector. Simply unplug that and drive.
There are a few ways around it to make everything function like stock but they're only a viable option if you're willing to live without the PCM for a week (if you plan on staying with a TS Performance chip platform).
Old Feb 28, 2016 | 05:25 PM
Xcelor8's Avatar
Xcelor8
Interesting... , I would like the PATS to still work, but that's not a HUGE concern.
Do I have to unplug the pats to make it work, or does that just get rid of the light? or will I have the light no matter what, unless I send the pcm out?
Looks like I have a bit more research before I'm ready to commit to the chip, at least for today, I'm going to put it back in stock, so I can drive the kids to school in the morning and hopefully figure it out tonight or tomorrow.
Old Feb 28, 2016 | 05:29 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Unplugging the module just gets rid of the light. The PATS will no longer be functional. Everything else will work fine.
To make the PATS work, the PCM will have to be sent to someone who can read it and put the section of the operational code of the PCM that the PATS module "looks for" in the binary code of the chip.
The DP-Tuner offerings as well as the Hydra allow PATS to work out of the box.
Old Feb 28, 2016 | 05:31 PM
Xcelor8's Avatar
Xcelor8
Thanks! I really appreciate your help.
Oldanvilyoungsmith
48
May 23, 2026 07:15 PM
snakedoc
Ford Truck Parts for Sale
Sep 30, 2012 12:13 PM
Orr353
Jul 3, 2011 02:39 PM
papadelogan
13
Dec 10, 2009 08:41 AM
foxracing0934
Jul 2, 2009 05:12 PM
