Ignition trouble
Old Feb 28, 2016 | 12:33 PM
dlburch's Avatar
dlburch
Originally Posted by killerstroke
Clean the battery terminals on the cables, they need to be bright clean metal. If you don't have a proper terminal cleaner (wire brush ones suck) scrape it to bare metal with a knife.
I have to assume you are putting the jumper cables right on the battery terminals.
I agree with Killer based on the description of your symptoms. If everything works as expected when you jump it, most likely a bad/dead battery or the terminal of either your + or - cable are corroded and they are not making a good connection on the battery posts...
Old Feb 28, 2016 | 06:22 PM
crazedfox's Avatar
crazedfox
Go back to basics.
Go over every connection of parts you replaced & check for correct wiring & make sure everything is tightened to spec.
Plus double check all connections for cleanliness & are connected proper.
Should have 3 grounds going from battery to:
Engine block (somewhere under/near alt. usually bolted to cyl.-head or block itself)
Down to frame/chassis (should have a "star" washer under it. -barbed washer-)
Radiator support.
You should also have a ground from back of engine to fire wall.
These grounds are important & without them, it can lead to issues.
Old Mar 3, 2016 | 06:50 PM
Shedsquatch's Avatar
Shedsquatch
Turns out the new alternator was bad. Being out of the game a while I realize to not realize that just because a part is new doesn't mean it ain't the problem. Thanks for the tips & keep on truckin'!
Old Mar 3, 2016 | 07:06 PM
crazedfox's Avatar
crazedfox
ShedSquatch,
Good to hear it's running.
How come you didn't check voltage @ alternator's batt.+ post when it was running, after fresh install?
Old Mar 17, 2016 | 06:32 PM
1977FORDF150's Avatar
1977FORDF150
Also give a good tug on the battery cable ends one may be loose, I expansive to replace
mark227
Dec 16, 2016 12:17 PM
esco24
Nov 27, 2007 10:41 AM
Junior57
1978 - 1996 Big Bronco
Aug 18, 2005 07:36 AM
teamwizard
Dec 23, 2002 04:54 PM
