SEARCH Mustang tank , you put it under the Bed in between the frame rails .
I did it to my 68 , couldn't stand the Gas smell and having 18 gallons of gas inches away from me .
Thanks guys, I don't mind the gas behind the seat so much but I could use the storage and i would like to weld up the goofy neck hole and I thought a little extra weight behind the rear axle would help.
... couldn't stand the Gas smell and having 18 gallons of gas inches away from me .
Maybe there are reasons to move the tank, but these ain't it. There won't be any fumes in the cab provided the sender gasket and the fuel filler hose is good. It's not an issue.
