2004 F-550 Front Axle bearing - advice on parts
When we removed the wheel to change the brake pads, we noticed the stub axle for 4WD is rattling in there, the bearing and seal are gone. Picture attached with arrow to indicate bearing.
Can anyone help identify the parts required? I am having difficulty finding a diagram that shows the parts clearly.
Any advice on stripping this down? Should I do both sides while I am at it? The left side looks Ok.
Thanks for any help on this.
2004 Ford F-550 front axle bearing and seal failed
From the pic the axle tube looks dry, if so the seal is good. You will have a little play in the axle. Other than the snap ring at the hub it pretty much just sits in there only supported by the side gears in the diff and out at the wheel hub. The axle seal isnt at the end if the tube but in at the differential.
BillyBob69
07-27-2018 02:06 PM
