Fuel issues.....
Old Feb 25, 2016 | 06:03 PM
AMDFX8150's Avatar
AMDFX8150
Fuel issues.....
Alright guys, my 1994 F150 keeps throwing a 172 oxygen sensor code (Indicates Lean). smelling the exhaust of this thing will choke you out. It has a brand new O2 Sensor in it (Bosch 15717). and it didn't physically change anything like Idle or exhaust smell or MIL codes 172. tried to unplug it and still no difference Same 172 code. Truck has a New Cat. Will NOTE O2 Sensor sits in the bridge that crosses the 2 Pipes. This truck has a Factory MAF, Can Confirm MAF and not MAP. no visual vacuum leaks But, there appears to be a Metric ****-ton of carbon in the intake past the butterflies. OHM readings off the ECTS are unknown. Any help would be greatly appreciated as its been doing this since I owned it (little over a year)
Old Feb 25, 2016 | 06:47 PM
rla2005's Avatar
rla2005
Exhaust leaks upstream of the O2 sensor will make the computer dump in more fuel since the unmetered air is causing the O2 to interpret this as a lean condition.
Old Feb 26, 2016 | 11:41 AM
AMDFX8150's Avatar
AMDFX8150
Wow that was quick, and Yes there is a leak where the manifold meets the Y pipe, Is that what is causing all this bull****?
johare
1983 - 2012 Ranger & B-Series
15
Feb 10, 2025 08:52 AM
whodatsaints
16
Jan 14, 2024 03:32 PM
bighibbi
1997 - 2003 F150
Sep 19, 2007 06:31 PM
Jharger
Apr 23, 2005 12:39 PM
Powerkleen
Feb 3, 2005 11:58 PM
