Engine harness fire
Old Feb 25, 2016 | 10:02 AM
infinite-foamies's Avatar
infinite-foamies
Engine harness fire
Hi guys, I had a wire on the positive of the GPR in case I need to hardwire it in the future because I can only access it by puling the tranny or the turbo(aftermarket). it grounded out on the manifold while the GP controller was cycling the relay and burned up a R W/ GN wire on the engine harness and now I don't get a WTS light nor does the fuel solenoid activate.
I added a wire providing +12VDC to the middle connector on the IP and It runs and I hear my GPR click.
Is this bad for the harness?
Would fixing that one wire fix my issue?
Old Feb 26, 2016 | 08:51 PM
speedwrench72's Avatar
speedwrench72
the power source for the gp controller is the same wire that provides power for the advancer and high idle, and FSS...separate from the large wire to the gp relay gets its power thru a fuseible link at the starter solenoid (poss bat post) one is a low current and the other, the big wire is heavy current. read the stickys...
Chips2000
Apr 12, 2018 09:09 PM
cbutcher
Sep 6, 2017 06:20 PM
bluesmanmike5
Sep 8, 2011 01:00 PM
trike1946
16
Dec 2, 2004 06:57 PM
love2fixit
Jan 7, 2003 05:35 AM
