Overheating problem
Old Feb 28, 2016 | 08:29 PM
86pullerf350's Avatar
86pullerf350
Ok I was able to take the t-stat out when i got home tonight. I found 2 major problems! <br/><br/>1) Obviously broken in 2 pieces!<br/>2) Made in china POS!<br/><br/>I'm going to replace the t-stat maybe tomorrow and hopefully that works and solves my problem.
Old Feb 28, 2016 | 08:34 PM
86pullerf350
Originally Posted by hairyboxnoogle
Needs temp gauge sender, buys t-stat and rad. cap... did i miss something?
Never said I needed a sender, only that I could try replacing it. It's $43 from Ford, I'm starting with the less expensive things first.
Old Feb 29, 2016 | 08:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
was that t-stat installed backwards???
the "bulb" is supposed to be in the engine, not the cap.
Old Feb 29, 2016 | 10:45 AM
86pullerf350
The picture is before I touched the t-stat. Was just bouncing around in there!!
Old Feb 29, 2016 | 03:34 PM
tjc transport
i ain't rite
so not only did the idiot put the wrong t-stat in, he put it in backwards!!
no wonder it overheated!
Old Feb 29, 2016 | 05:25 PM
86pullerf350
Yes he did!! Loaded it up with silicone too.
Old Feb 29, 2016 | 06:19 PM
tjc transport
i ain't rite
some people should not breed.
and if they do, doctors should be allowed to euthanize the babies before they grow up to be morons like their parents!!!
Old Feb 29, 2016 | 06:35 PM
86pullerf350
That's some funny stuff right there!!! LMAO!!! But true!! Or if they don't know what they're doing, don't touch it!!!
Old Mar 1, 2016 | 05:30 PM
madpogue's Avatar
madpogue
I'm picturing it now; when he reefed down the t-stat housing bolts, it obviously didn't occur to him that it was taking excessive effort, and he just took the knucle-dragger approach and kept cranking. As the housing seated, it pushed the protruding wrong end of the t-stat downward until it eventually gave way. Also explains why he needed the pound of RTV. Wow. Just wow.
Is that a reference to the truck, or the breeding?...
Old Mar 2, 2016 | 08:38 PM
86pullerf350
Well I got the new t-stat and gasket installed the right way, topped off the coolant, and took it for a nice long ride today. Did some back country roads and some interstate cruising at 80! I watched the guage and it never went above the N, even on the one mile hill to get home!! So sender and sensor are both fine and functioning properly!! Thanks for all the help and suggestions guys!! I did the oil change as well today! Only problem is that I have to replace the hose clamp on the t-stat hose end of the upper radiator hose! New cap also held good pressure.
Old Mar 3, 2016 | 12:35 PM
tjc transport
i ain't rite
thedopefishlives
Jul 10, 2018 02:08 PM
Wayne Waldrep
61
Apr 11, 2014 06:37 PM
70torino429
Apr 16, 2012 03:21 AM
Superdave37076
1983 - 2012 Ranger & B-Series
Apr 30, 2005 11:20 PM
prginocx
May 14, 2004 01:12 PM
