Sponsored by: Real Truck
No start cold
Old Feb 23, 2016 | 03:03 PM
Jere Miah's Avatar
Jere Miah
No start cold
Ok 2008 f250 5.4L 4x4. Replaced starter,altinator,battery. Also changed out positive and negative terminal conections. When temps reach 35 or below the truck wont start. Warmer temps starts just fine. Put key in ignition plenty of power to run plow or radio but no click or crank.
Old Feb 23, 2016 | 03:37 PM
nmclella's Avatar
nmclella
Did you check the starter solenoid/relay?
Old Feb 24, 2016 | 06:56 AM
Jere Miah's Avatar
Jere Miah
Starter and celenoid are one unit. I checked all the fuses for corosion and blown. The relays i check even switched them(ones with same number/conect patern) just incase one was malfunctioning. Made no difference.
El Campo
Feb 13, 2019 08:08 PM
jamesaero
Jan 14, 2015 09:29 AM
datzsun
Bronco II
Feb 20, 2008 01:30 AM
ttow
Feb 12, 2008 09:04 PM
shaun327
Aerostar
Aug 6, 2003 02:10 PM
