Truck Leaning 1.5" to the Left
Ever since I bought the truck I have noticed it has leaned slightly to the left. I even had a dealer look at it a couple months ago, but they said it was within Ford's tolerance. It has gotten progressively worse, and the odd thing is it's most noticeable with the bed of the truck completely empty, less than 10 gallons of fuel in the tank, and under a half tank of DEF. Below are some pics I took with the load in the truck as light as possible. When these pics were taken, there was a 1.5" difference in fender height from left to right, which is way outside of Ford's specs. I have a service appointment at another dealer on Saturday to see what they say.
Shot from inside garage.
Level on rear bumper showing how extreme the lean is.
Level on driveway showing it is level side-to-side.
Measurement of left rear fender to bottom of wheel.
Measurement of right rear fender to bottom of wheel.
My best guess (and the dealer i have the appointment with) is it's a defective spring on the driver's side. Looking at the top overloads on the springs, the left rear is always much closer to contacting the bump stop than the right rear, which seems really odd. I just hope it's something easy to diagnose and quick to repair.
While the truck is at the shop, they are going to also look at a noise that's recently developed in the wiper linkage, as well as reprogram the computer for my larger fuel tank and wheels and tires, and adjust the TPMS sensors to account for the lower maximum pressure of the new tires.
Is it possible to measure from the bottom of the frame rails to the floor on both sides and front to rear?
If one side of the frame is lower than the other, then I'd shim at the springs on the axles. If the frame sits level, then the body mounts need shims but make sure the cab and the bed are both shimmed, otherwise you'll have a noticeably crooked bed.
On an unrelated note, my wheels should finally arrive today. If they do, I'll be posting some pics of the new wheel/tire package on the truck tonight as well.
I guess it's a possibility, I'm just glad I never park on a level surface. If I knew my truck is crooked I might go crazy too.
