Another dual tank question
Old Feb 22, 2016 | 01:02 PM
Big_Al59's Avatar
Big_Al59
After many lucky years without seeing this first hand it finally hit my truck. The front tank feeds into the rear tank or onto the ground. Rear tank works but takes a little extra cranking to start vehicle when warm. Based on my searching it looks like the fuel delivery module is bad on rear tank. If I'm wrong let me know. What I don't understand is the front tank will pump out fuel even if I'm running on back tank. I haven't used front tank in couple weeks, the other day I put 5 gal in front thinking it would stay there since I was using back tank. Checked yesterday & it's completely empty. Is it normal for both tank pumps to run at same time like that? Thanks
93 f250
Old Feb 22, 2016 | 01:11 PM
subford's Avatar
subford
No it is not. Only one runs at a time.
Old Feb 22, 2016 | 06:18 PM
ChRoNo16's Avatar
ChRoNo16
Wouldn't that mean the valve that switches from one to the other is bad?
Old Feb 22, 2016 | 07:27 PM
subford's Avatar
subford
No there are no switching valves for selecting the fuel tanks.
You would have to have a bad selector switch on the dash or a shorted wire.
Gstan
Apr 14, 2019 06:20 PM
cclc1021
Nov 28, 2006 09:55 PM
ac700wildcat
27
Nov 26, 2006 04:12 PM
digr
Feb 7, 2005 08:01 PM
chrisvman
Feb 6, 2005 10:15 PM
