Front Shock replacement E150 - 2012
Old Feb 22, 2016 | 09:12 AM
rprzybylski's Avatar
rprzybylski
Hi All,
I have tried to replace the front shocks on an E150 van and am having issues. My long socket is too long and my short is too short to fit over the upper bolt to remove it. I have an offset box wrench but it also doesn't fit - slightly too small of an offset. This can't and shouldn't be this difficult. Is there a special tool for the removal of the upper nut? I haven't looked at the lower. Is there anything I should know about that so I can get this accomplished pretty quickly?
Old Feb 22, 2016 | 03:12 PM
jbwheels's Avatar
jbwheels
Originally Posted by rprzybylski
Hi All,
... This can't and shouldn't be this difficult ...
Oh, but it is...
I assume the 2102 is the same as a 98. The lowers were easy. The uppers were a pain.
I cut the shock shaft with the sawzall to get them out. If you don't have a recip saw buy one. Even with a trip to the store to get one it will take less time than trying to loosen the top nut on the front shocks and you'll have a cool implement of destruction.
As I recall, I used a ratcheting wrench and combo wrench moving what seemed like 1/360th of a turn at a time to tighten them up. I could not get any socket+ratchet/breaker on the nuts.
I simply hit the lowers with an impact gun. If you live in a corrosive environment, soak them the day(s) before with your favorite lube, then heat them with whatever you have (I use a propane torch) to be sure you don't twist the stud out of the arm.
Old Feb 23, 2016 | 06:42 AM
JWA's Avatar
JWA
Originally Posted by jbwheels
Oh, but it is...
Yeah---agreed here ^^^ ! FWIW top shock mounting from '92 to end of life were pretty much the same, calling them a PITA is an understatement.
This is made more difficult (without a cutting tool) if the so-called double tube type cheaper shocks are used, those with the metal shield over the shock body and shaft for protecting the moving parts. Once the top nut is stripped or its frozen in place impossibly cutting them out is the only option.
When installing new shocks look for something in the budget that have a "mono-tube" design, similar to Bilstein. Those have wrench flats below the upper mounting threads that make removing them vastly "easier".
Use a liberal amount of anti-seize on those threads---also making things "easier" come next removal time.
HTH
Old Feb 23, 2016 | 08:16 AM
rprzybylski
Thank you to all
Thanks guys - I was hoping for an easier solution and had though that would be the way I would have to go. I appreciate the help.
Who was the designer for this one? We need to take him out back and show him how to do it right.
DriverD
24
Oct 2, 2018 11:34 AM
kevin-11
17
Sep 20, 2017 03:51 AM
tps93ranger
20
Feb 20, 2014 06:52 AM
fods
Jan 18, 2012 12:36 PM
996cup
Oct 27, 2011 06:38 PM
