Sponsored by: Real Truck
Rain guards and auto windows
Old Feb 21, 2016 | 10:24 PM
Fordboy880's Avatar
Fordboy880
I have a 13 f350 and I'm looking into rain guards for my windows. I really like the look of the guards that sit in the tract of the windows vs the type that stick on with tape. But as some silly saftey feature of the truck the windows will roll down if they detect something blocking the window while it is rolling up. Will these cause an issue. Anyone else have this setup?
Old Feb 22, 2016 | 05:09 AM
chickfisher69's Avatar
chickfisher69
I just installed the weather tech window visors in my 2016 f250 with auto up and had to do a reset ,now they work fine .
Old Feb 22, 2016 | 05:41 AM
msgtord's Avatar
msgtord
I had to keep my windows up for a couple of days because it would reach the visor and auto down. After it set in it is fine.
Old Feb 22, 2016 | 06:48 AM
Fordboy880's Avatar
Fordboy880
You had to do a reset? What is it to be reset? And if I understand what your saying is, the windows will detect the extra resistance and adjust to it? If so that's pretty cool, or is there some break-in period for the visors and seals?
Old Feb 22, 2016 | 08:03 AM
msgtord's Avatar
msgtord
"And if I understand what your saying is, the windows will detect the extra resistance and adjust to it?"
Actually, if the window is in the fully closed position, it will press the visor into the channel. After a couple of days the plastic conforms to the shape of the channel, and the gasket in the channel compresses allowing the window to operate properly. I did not have to reset.
Old Feb 22, 2016 | 08:54 AM
fordman19762003's Avatar
fordman19762003
just get the outside the channel type and you won't have to worry. The outside the channel kind will not damage your paint, my last truck was 10yrs old when one of the visors came loose and the paint was perfect behind it.
Old Feb 22, 2016 | 10:41 AM
RedHorse1's Avatar
RedHorse1
Like Chick I installed Weather Tech and have had no issues with them.
Old Feb 22, 2016 | 11:46 AM
mikereidjr's Avatar
mikereidjr
I have the in channel kind, I just waited for a warm sunny stretch of days and installed them and just parked outside for a few days with the windows closed.
I haven't had trouble since the install.
Old Feb 22, 2016 | 11:57 AM
don123's Avatar
don123
I like the stick type too. My last truck had the visors on for 10 years and when one broke I peeled it off and the paint was perfect.
Old Feb 22, 2016 | 12:46 PM
dkf's Avatar
dkf
My dad wanted a set for his 15'. I didn't want to screw with the auto up and in channel viser issues so I got stick ons.
These are the ones I got. They fit well and the install was easy. They do pretty good for keeping water even though they are not that big. What sold me on these vs others is how they extend further front on the front windows so rain doesn't end up on the window and mirror controls.
2015 Ford F250 Wade Tape On Rain Guards - 15% Off at RealTruck.com
Old Feb 22, 2016 | 02:07 PM
wallacemf's Avatar
wallacemf
I just installed the Putco low profile in-channel visors. As others have stated, the window needs help the first time you put it up. Leave it up for 48 hours to adjust, and it's fine after that.
Old Feb 22, 2016 | 03:33 PM
SuperDutyScaler's Avatar
SuperDutyScaler
I have auto vent shades on my 2004 and they stick to the rubber window seal not the paint. In the front you loosen the mirror bolts and slid the visor under it and then retighten. My passenger one came off a few years back, after being on since new in 2004 and all i needed was a heat gun and then goof off to remove the leftover double sided tape and I installed both new ones in a half hour
Old Feb 23, 2016 | 12:40 PM
speakerfritz's Avatar
speakerfritz
anyone have links to the in channel type. the out of channel type always leak and sometimes blow off.
Old Feb 23, 2016 | 01:18 PM
Mike189677's Avatar
Mike189677
I've had the stick on ones on all my trucks on the super duties they stick to the rubber just like scaler said no need to worry about messing up the paint just follow the directions and I think the stick on ones look better
Old Feb 23, 2016 | 04:32 PM
chickfisher69
After having the weather tech visors installed for 4 days. My wife and I realized that it was louder in the cab. Removed the weather techs and it is a lot quieter. I will be going back to the avs shades I had on my 2010 f 350 stick to the rubber ones .They worked fine.
