Yep here you go
Bar- txd-07eo221442 rxf-046285140640 rxd- 3010 mth- 001d00500000
Ebp-txd- 07e0221445 rxf-046285140645 rxd- 3010 mth- 00100050???? You need to find what your psi is for map boost mine was 13.3 so the numbers at the end of mth is = ff7b I'm trying to find the scan gauge book that tells how to do it and all the numbers maybe go to SG site
Sorry boost reading BST not map go to the SG site under XGauges ford specific down under the boost will be the xxxx list of readings determine what boost is under the xxxx then enter the numbers for MTH Walla should work
