Done with Motorcraft...
Old Feb 21, 2016 | 03:05 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Batteries!!!
Giving the Advance Auto Platinum AGMs a shot... I stuck it to the man by buying the individually and using the TRT30 code!
I sure hope they last longer than the MC batteries! I have been lucky to get 3 years out of them.
Old Feb 21, 2016 | 03:18 PM
Jmoen7's Avatar
Jmoen7
3 years is pretty good from what I've experienced, especially in the cold
Old Feb 21, 2016 | 08:18 PM
LindenBruce's Avatar
LindenBruce
I only (LOL) got 6 years two months out of my last set of AC Delco 850CCA lead acid batteries. Hoping this new set lasts as long. B.
Old Feb 21, 2016 | 08:28 PM
WatsonR's Avatar
WatsonR
Me too... bought mine about a month ago... but that TRT30 sure makes it easier to swallow, especially the $100 bill I saved!
Old Feb 21, 2016 | 09:20 PM
Restlesswildman's Avatar
Restlesswildman
Autozone is the only way to go on Batteries!
Old Feb 21, 2016 | 09:40 PM
04badford's Avatar
04badford
Most Costco's changed to Interstate working on 4 years so far,
Old Feb 21, 2016 | 09:46 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
We are getting our first Cosco in OK soon! Perhaps that's where the next set will be bought... Just hope it's 4-5 years down the road!
Old Feb 21, 2016 | 09:56 PM
04badford's Avatar
04badford
I've had good luck with Interstates Costco brand not so much I think that's why Costco has been faxing the other Kirkland maker out, I picked both battery's up at our local farm Ag dealer interstate still has a good warrantee , make sure the cables and Alt is tip top
Old Feb 21, 2016 | 11:34 PM
jswartz84's Avatar
jswartz84
Dang, my original Motorcraft batteries lasted 8 years. Never once did I put a charger or maintainer on them. I figured since I had such good luck with them I would buy a second set. Almost 3 years and they are still treating me well..
Old Feb 22, 2016 | 03:18 AM
Yahiko's Avatar
Yahiko
Ready for the deli ??? Good Hotdogs.
But onto the battery thing. I find that the batteries that first come with
any vehicle seem to last way longer than any replacement ones so.
3 Years on a set is not bad if you only have a stock alternator and pulley.
Sean <BR>
6.0L Tech Folder
Old Feb 22, 2016 | 05:46 AM
TooManyToys.'s Avatar
TooManyToys.
That's because the OE assembly line batteries are different then the aftermarket Motorcraft or any other aftermarket.
I'm also starting to wonder if we may be hurting ourselves going to a higher CCA then stock as from what I've been reading we may be sacrificing higher volume capacity for less durability, 850 vs 650.
As long as your driving conditions have enough time to fully charge the batteries then the alternator size won't matter, they only accept so much current.
Old Feb 22, 2016 | 06:17 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
My Father N Law has my first 6.0 and he has had the same experience. He was able to get them both replaced under warranty tho. I was just outside of that.
I upgraded to the 140A alternator about 1.5 years ago. My drive one way to work is about 20 miles so I would think that would be sufficient time to charge the batteries?
That all being said I just accepted a new position at work that comes with a companies car (yeah it has a bow tie ). So my next purchase will be a battery minder to keep those new batteries healthy.
Old Feb 22, 2016 | 06:35 AM
MisterCMK's Avatar
MisterCMK
My interstate rep replaced my mtp65 batteries again and said that he is moving me over to the c65 batteries. Said that the ford diesels seem to go through batteries and moving to the commercial series, while a lower CCA, made them last longer. Didn't cost me anything...
Old Feb 22, 2016 | 08:08 AM
timmytoes's Avatar
timmytoes
Shane, I eneded up going with advance batteries a few months back and doing the same thing you did with the trt30. Saved a lot of money and if they don't last through warranty, at least there is a advance in practically every town to get them replaced. So far, so good. They're still really strong but it hasn't been very long. We'll see!
Old Feb 22, 2016 | 08:13 AM
timmytoes's Avatar
timmytoes
I was wondering about that when I changed mine last time. Mine came with the Motorcraft 650 cca and they lasted 7 years I think. And since I went with 850s I've gone through 3 different autozone sets. I'm now on the 4th set but they're from advance. I could've kept getting free ones from autozone but they crapped on me too often to keep going with them.
