Ford 289 identification and salvage
Hi guys - not much of an expert in Ford engines. I have this old 289 I believe that I took apart for fun. Wanted to know how to read the stampings on it. Believe its a 64.
Also there is some serious damage to one of the cylinder walls you can see from the images. Looks bad to me. Do you think its worth re-building this engine? Can a machine shop do anything or is it just not worth the effort?
Thanks.
Damaged cylinder wall 1
Another view of the damaged cylinder wall
Block stampings
Thanks.
Block stampings
Looks like it's been sleeved already to fix the damaged cylinder. Are all the cylinders like this? This appears to be a 1964 casting, so it probably has a 5 bolt bell housing pattern. If you need a particular vintage of engine for date matching, or if you're trying to mate it to a similar vintage transmission, you would need a replacement block of the same era. But if all you're after is a small block Ford v8 engine to fit a newer transmission, lots of better cores are available for dirt cheap.
Thanks. The other cylinders are fine. I am worried about the integrity of that damaged cylinder and wasting too much money at the machine shop. I have access to another 289 and I am trying to learn about engine rebuilds and have a car in mind for the engine. I am not too worried about matching.
on
As mentioned, it's a 5-bolt block rather than the later 6-bolt so unless your project specifically requires the early bolt pattern for authenticity and to mate to the bellhousing/transmission, I'd look for another block to build. I don't see the sleeved cylinder as being that much of a problem if you do need to build it, but I'd go for a 6-bolt block personally. (The change from 5 to 6 occurred in 1965) And the 5-and-6 bolt patterns are not interchangeable:
However, if you do build another block I'd hang on to that one, 5-bolts aren't all that common any more and someone may need it at some point for an authentic restoration.
You can also use a 302 block and put the 289 internals into it.
Received 3,107 Likes
on
TMI
07-30-2017 03:17 AM
Kahunajohn
01-01-2015 11:52 PM
blisstruck
21
11-19-2010 05:01 PM
51PanelMan
04-03-2005 11:07 PM
MustangGT221
12-21-2004 10:44 PM
