Injector knocking?
Old Feb 19, 2016 | 02:54 PM
BogginDave's Avatar
BogginDave
Injector knocking?
I have to post this since I just noticed today. I have a knocking noise coming from the passengers bank. Not sure which one, but I can hear it mostly from inside the cab when idling. My truck has low miles, almost at 100k. The previous owner treated her with care, but towed a lot, and I mean A LOT. Not sure how much strain that'll put on injectors, but I've also noticed how my mpg are not what I was getting when I first bought the truck. I bought remans just in case. Also, how long do glow plugs continue to operate after starting the truck? Thanks in advance.
Boggin Dave
1996 f250 xlt auto 2wd 96,668
Old Feb 19, 2016 | 03:50 PM
fordpride's Avatar
fordpride
Loose injector or low fuel pressure
Old Feb 19, 2016 | 05:01 PM
fordman67's Avatar
fordman67
Remand?!?! Uggg take em back!!!!!
Old Feb 19, 2016 | 05:03 PM
BogginDave's Avatar
BogginDave
Hehe yup I'm packing them up right now.
Old Feb 19, 2016 | 05:04 PM
BogginDave's Avatar
BogginDave
If it's a loose injector can I pull the cover off and just tighten?
Old Feb 19, 2016 | 06:00 PM
z31freakify's Avatar
z31freakify
Yes sir, torque should be 128in lbs.
Old Feb 19, 2016 | 06:29 PM
BogginDave's Avatar
BogginDave
Sweet! Thanks
Old Feb 19, 2016 | 07:42 PM
fordman67's Avatar
fordman67
If one is loose then the heat of combustion most likely has torched it. If you find a very loose one you should prob pull it and check it out.
Old Feb 19, 2016 | 07:48 PM
fordpride's Avatar
fordpride
X2^^^
If the injector lifted the heat from the cylinder will destroy the orings
Old Feb 19, 2016 | 07:51 PM
z31freakify
^^^ x3 check the injector O rings
Old Feb 20, 2016 | 07:52 AM
Talyn's Avatar
Talyn
Easiest way to tell if you have an injector issue is to do a buzz test if you have the capability.
Start test, listen under the hood.
Check the sheet for the buzz order.
You'll know if you got an issue when you got one that buzzes really really odd.
Old Feb 24, 2016 | 07:53 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Buzz test only checks the IDM, wiring, Solenoid, etc, and does nothing to indicate issues with the oil or fuel sides. More diagnosis is needed to help narrow down.
If there is one loose, you can knock them all on top with a mallet then check torque of the hold-down bolt. If you find one (or more?) that take substantial turns of the wrench to tighten, then that injector should be removed and probably rebuilt.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
quesey
Aug 19, 2018 06:18 PM
Rxracer27
17
Jan 5, 2014 04:59 PM
arkredneck
Aug 20, 2011 10:13 AM
jwhite1993
24
Feb 8, 2009 10:30 PM
Pele
Jul 17, 2008 11:35 AM
