1996 f350 7.3 injector problems.
Old Feb 20, 2016 | 10:14 PM
madpogue's Avatar
madpogue
The injectors are 120VDC, and the common (center terminal) is the positive. The individual injector wires on each connector are grounded in their turn by the IDM to complete the circuit. Given that it's now #5 and #7, that passenger rear connector, and its corresponding connections under the valve cover, are the prime suspects. Did you include the common center terminal in your continuity tests?
Old Feb 20, 2016 | 10:34 PM
Searcysautos's Avatar
Searcysautos
I tested from the injector itself to the IDM.
Old Feb 20, 2016 | 10:54 PM
madpogue's Avatar
madpogue
So you checked both terminals at each injector?
Old Feb 21, 2016 | 06:27 AM
Searcysautos
Yes I did.
Smokey_7.3
Aug 22, 2014 03:58 PM
j1msevier
Mar 6, 2013 06:14 PM
DCook909
19
May 24, 2011 08:54 PM
bigdog55
Aug 2, 2008 08:41 PM
caprang
Mar 19, 2008 08:32 AM
