1940 Ford Marmon-herrington 6X6
#46
rubber casting
Rubber bushings for the drag links are shot. I found a two part polyurethane that has the same durometer as the old rubber that can be mixed and directly cast into the body of the link and encapsulate the tapered mount. VytaFlex® Series Urethane Rubber Product Information | Smooth-On
#47
About a hundred US for a gallon in total. That's a lot of bushings for a hundred bucks. I don't have much choice as some of the parts I need aren't made or reproduced anymore. I use vytaflex 30 all the time to make molds for casting so I know the product. You don't have to mix the whole gallon at once so it can last a long time. I'll post the process once I get the links all cleaned up.
#48
If I may take you back to your first page where you found the stock 18" wheels on one side with the 20s on the other side. If you still have the 18s, may I ask you to look for part numbers on them. Probably on the concave rim lips. Few other trucks of the era used 18s, and I'm wondering about their width and offset. Thanks. Stu
#49
#51
Polyurethane bushings
Got most of the drag links sandblasted, powder coated and cast the poly urethane bushings in place.
Had to use a drill to remove the old disintegrating rubber bushings
Sandblasted and powdered the old links. Taped up the parts I didnt want covered in polyurethane. Centered the pivot points in the ends of the links and poured in the poly.
I poured the urethane over the taped up ends and let it run down and fill the cavity. Vytaflex has the consistency of honey, isnt full of bubbles and has a working pot life of an hour.
#53
#54
This particular mix is just like hard rubber. You can flex it but it is tough like a lacrosse ball or a car tire. It says it will stretch 400% before it will tear and the Poly doesn't have a memory like rubber so it should last. The mix is available in a range of strengths. See my previous posts with the link to the manufacturer.
#56
#57
#58
#59
