Transfer case use question
Old Feb 17, 2016 | 08:26 AM
Ruffasacob's Avatar
Ruffasacob
I know I'm going to regret asking this question because the answer is probably really obvious, but I've been pondering and can't come up with an answer. Why is there a 2H in the shift pattern, (1966 F250)? When would you use 2H?
If I want 2 wheel drive I put the transfer in neutral and unlock the hubs.
Old Feb 17, 2016 | 09:15 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Sounds like you could use a 1966 Ford Truck Operator's Manual, sometimes referred to as an owners manual. It covers proper operation of your Transfer Case.
But, you are probably slipping it into the undocumented 2L position. Read this thread. In a nutshell there is a long throw between Neutral and 4L and you are finding the other selection. 2L is OK for off-road, but if you are going on the highway then you'd want 2H for that. Neutral - when you are actually in Neutral - doesn't provide power to the front or back wheels. You'd use Neutral to sit in one spot and run something off of a PTO.
https://www.ford-trucks.com/forums/1...l#post13154389
Dave_north14
16
Aug 24, 2013 12:30 AM
Reefmonster
Aug 8, 2011 07:27 PM
jason867
Oct 24, 2007 09:37 AM
matt77F2504x4
Offroad & 4x4
19
Feb 2, 2005 08:35 PM
shore19
Aug 31, 2003 09:00 AM
