Transfer case question
Old Aug 30, 2003 | 03:39 PM
shore19's Avatar
shore19
I have a 1988 F250 aod trans and I'm not sure which transfer case, anyway my question is I can put the transfer case in 4H and 2H but it wont budge going into neutral or 4L.
Any Ideas?
Thanks,
Jim
Old Aug 30, 2003 | 03:41 PM
AlM's Avatar
AlM
Jim, Our 96 and ex 78 needed to be in Park/Neutral..then shifted to N/4 low; sometimes a slight forward motion was also needed before trying 4 low/or N shift again.
here are X fer case images to help you ID:
http://www.truckpulls.com/Transferca...mage_Index.htm
Old Aug 30, 2003 | 03:52 PM
shore19's Avatar
shore19
Ok, I will try that again, it just seems wierd about two weeks ago I could just use my finger to pull it back into 4L, now im yanking and not getting anywhere. Thanks for the link.
Old Aug 30, 2003 | 04:06 PM
shore19's Avatar
shore19
Alrighty thanks for the input AlM
you were right on target....pun intended I guess it was just not sitting in the right place. Working good now.
Thanks again
Old Aug 31, 2003 | 09:00 AM
AlM's Avatar
AlM
good!
