po8a7 code
Old Feb 16, 2016 | 09:17 PM
Millick's Avatar
Millick
po8a7 code
need help boost gauge is pegged and have no turbo dont know if the code has anything to do with the problem or not its a po6a7 any help would be great
Old Feb 17, 2016 | 05:12 AM
senix's Avatar
senix
sensor range b code.
I would take it in. Do not erase the code.
It would also be helpful to the tech if you can video the boost while driving or with the motor running.
Old Feb 17, 2016 | 07:44 AM
Millick's Avatar
Millick
It's tuned and deleted and out of warranty don't want to pay them the dealers around me suck we own a shop I put it in the computer and the camshaft sensor is saying fault
Old Feb 17, 2016 | 09:58 AM
senix's Avatar
senix
curious if that fixes the issue. Really could find much on the code.
Old Feb 17, 2016 | 10:55 AM
darren32's Avatar
darren32
Do you mean P06A7?
P06A7 - Sensor Reference Voltage B Circuit Range/Performance
Description: See the description for DTC P06A6.
Possible Causes: See the possible causes for DTC P06A6.
Diagnostic Aids: See the diagnostic aids for DTC P06A6.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to Pinpoint Test B .
P06A6 - Sensor Reference Voltage A Circuit Range/Performance
Description: Indicates the reference voltage (VREF) circuit is out of range.
Possible Causes: VREF circuit short to voltage
VREF circuit short to ground
VREF circuit open
Shorted sensor
Diagnostic Aids: The presence of this DTC may indicate that the vehicle is operating in derate mode and may experience a loss of power.
This DTC sets due to an out of range voltage condition on the VREF circuit.
Pin B attached
File Type: pdf
File Type: pdf
Old Feb 17, 2016 | 04:17 PM
Millick's Avatar
Millick
im getting 8-10 volts at the map sensor connector and same at the egr
Old Feb 17, 2016 | 08:26 PM
dlibson's Avatar
dlibson
That's a 5 volt circuit. You shouldn't have anywhere near 8-10. Looking for a short somewhere.
Old Mar 9, 2025 | 04:20 PM
snaponprofile's Avatar
snaponprofile
Bump. Were you able to solve this? Dealing with the same issue myself, driving me nuts.
Old Mar 9, 2025 | 04:26 PM
charlie g's Avatar
charlie g
FTE Community Team
sadly the OP's Last Activity: Oct 6, 2016 09:52 PM he made only 5 posts
jcmagone
Jan 3, 2024 08:16 AM
sandyc
6.7L Power Stroke Diesel
May 30, 2018 12:21 PM
sweatthawg913
2015 - 2020 F150
Oct 28, 2016 08:04 PM
HNTN247
Jul 7, 2010 06:27 PM
Big Fish
Jun 1, 2007 04:23 PM
