It would also be helpful to the tech if you can video the boost while driving or with the motor running.
It's tuned and deleted and out of warranty don't want to pay them the dealers around me suck we own a shop I put it in the computer and the camshaft sensor is saying fault
P06A7 - Sensor Reference Voltage B Circuit Range/Performance
Description: See the description for DTC P06A6.
Possible Causes: See the possible causes for DTC P06A6.
Diagnostic Aids: See the diagnostic aids for DTC P06A6.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to Pinpoint Test B .
P06A6 - Sensor Reference Voltage A Circuit Range/Performance
Description: Indicates the reference voltage (VREF) circuit is out of range.
Possible Causes: VREF circuit short to voltage
VREF circuit short to ground
VREF circuit open
Shorted sensor
Diagnostic Aids: The presence of this DTC may indicate that the vehicle is operating in derate mode and may experience a loss of power.
This DTC sets due to an out of range voltage condition on the VREF circuit.
