Okay need help no start cold.
Old Feb 16, 2016 | 08:26 PM
Pikachu's Avatar
Pikachu
When you were cranking it over, did the ICP psi stay pretty much steady, or did it vary? If it stayed completely steady, it may not be an accurate value. Did it kind of rise to 2300, or did it crank a while and suddenly jump? Is there a check engine light on? What are you using to monitor? I have no idea what ICP raw is . . .
Old Feb 16, 2016 | 08:46 PM
riley431's Avatar
riley431
It goes up and down around that. It goes up pretty quick. Raw signal.
Old Feb 16, 2016 | 08:47 PM
ExPACamper's Avatar
ExPACamper
I don't know, either, but it seems to be coming from Forscan when I've seen it posted
Old Feb 16, 2016 | 08:51 PM
riley431's Avatar
riley431
I have an infinity
Old Feb 16, 2016 | 08:56 PM
ExPACamper's Avatar
ExPACamper
Originally Posted by riley431
I have an infinity
Interesting. I'm not familiar with it, though. Doesn't mean anything, just not sure what to do with it
Old Feb 16, 2016 | 08:57 PM
riley431's Avatar
riley431
Well I ordered a cps from clay. The other option is there is still air in the system. I did drive it about 50 miles.
Old Feb 16, 2016 | 09:01 PM
Pikachu's Avatar
Pikachu
Well, I guess we can assume the reading is good, but it would be nice to confirm it with the ICP voltage reading. It's blowing white smoke while cranking, so there's at least some fuel being injected. I guess it's back to the basics. Have you checked the glow plug relay with a voltmeter? If you put the leads on the two large posts, you should read battery voltage with the key off, and close to zero volts with the key on and the relay commanded on by the PCM. It could just be a coincidence that something else went bad at the same time you did the other work.
Old Feb 16, 2016 | 09:02 PM
riley431's Avatar
riley431
I well check voltage at the posts tomorrow.
Old Mar 5, 2016 | 08:03 PM
riley431's Avatar
riley431
Update. Three cracked Pistons. Rebuild time.
Old Mar 5, 2016 | 09:03 PM
ExPACamper's Avatar
ExPACamper
Ouch. How did you find out?
Old Mar 5, 2016 | 10:22 PM
oldboots1950's Avatar
oldboots1950
U might check glow plug relay
Check glow plug relay. Just a drop of one volt across the large posts can cause a hard cold start. They just go bad some times.
Old Mar 5, 2016 | 10:26 PM
AllaboutMPG's Avatar
AllaboutMPG
Unfortunately, Glow plugs are not going to help our friend here
kc0ti1002
Nov 5, 2010 10:42 AM
bpiazza
Feb 11, 2010 07:51 PM
385seriesHemi
17
Nov 9, 2008 10:08 PM
Wolverine69
Feb 17, 2008 01:56 PM
whitesdford
Jan 4, 2006 12:29 PM
